FS: 1998 Legacy GT Project
Discussion in 'For Sale : Car Parts' started by Blageo23, Mar 10, 2011.
  1. Blageo23
    Blageo23 Well-Known Member
    Shoreview
    Contact:
    PM me
    Or email- [email protected]
    Asking Price- $6500
    1998 Legacy GT Sedan
    2.2l Turbo Motor
    Manual Transmission
    Green Exterior
    Grey/Black Interior
    282,000 miles on the chassis
    It is a running and driving car but listed it as a project because with the stuff included it could be a nice quick Subaru
    Exterior:
    JDM projector head lights
    HID High and low beam
    Engine:
    Everything motor related has 3000-4000 mile on it
    2.2L closed deck Rebuilt
    2.5L Cylinder Heads (Rebuilt)
    ARP head studs
    OEM MLS head gaskets
    ALL OEM GASKETS
    New Timing components(OEM)
    New WRX/STI Water Pump (OEM)
    Everything possible is powder Coated black
    All hardware was replaced with SS bolts
    New Plugs and Wires
    New Alternator
    New Belts
    Drivetrain:
    Manual Conversion parts were out of a 2001 Impreza Outback (80,000 miles)
    Clutch has 15,000 miles on it (OEM)
    Suspension:
    WRX suspension
    new front wheel bearings
    new front ball joints
    newer brakes all around
    brand new ebrake components
    Exhaust:
    Aftermarket Exhaust manifold
    3" mild steel cat back
    What is not installed but included
    JDM fog lights- one is broken
    "JDM" Turbo- not sure what one it is but it has a 90 degree elbow on the compressor cover
    WRX Exhaust manifold
    no name aftermarket down pipe
    STI fuel injectors with rails
    1992 Legacy turbo ECU with wiring harness
    2002 WRX ECU and short harness
    1992 Turbo Legacy cross member with newer steering rack
    I have owned this car for about 5 years now. Just recently started to do these modifications because the 2.5l blew the head gaskets for the second time. I put the new motor in at 280,000 miles and the transmission at about 282,000 miles. Car runs and drives fine. only thing wrong with it is it is sooooo slow being a turbo motor running NA. The car is loud due to the 3" exhaust. Putting the turbo on should quiet that down a bit. The car has brand new blizak winter tires on it. This thing is a beast in the snow. Only reason I am trying to sell it is because I have so many projects right now and I'm looking at buying a truck to haul my "nice car" around with. Please only reply if you are interesting in buying the car. I can answer any questions and I will point out all the flaws if you want. I don't like to hide things.
    Email me for pictures and any questions you may have.
    Oh and if you don't like the price, I and probably other people could care less.
  2. Blageo23
    Shoreview
    ***no i will not part out***
  3. PhilSine
    PhilSine Well-Known Member
    MNBugeye Mafia 007 (Superior)
    So it's an EJ22T engine but not yet turbo'd?
  4. Blageo23
    Shoreview
    correct. Comes with pretty much everything to turbo it tho.
