Hey I'm looking to possibly get rid of my car. It's a 2002 wrx that has been through an entire life change. I bought it almost 3 years ago with 147k and completely stock minus the HKS bov, rims and carbon fiber hood. The first thing I did to the car was getting it painted. The car is fully shaved minus the trunk lock hole. The gas filler neck was moved into the trunk. Then the car was painted House of Color Tangerine orange. After that I decided that it was time for some more power. I bought a brand new 2.5 block and rebuilt the heads and put a hta 68 on it. The car made 354 hp. After a couple thousand miles the car started going through antifreeze. Turns out the heads were cracked. So it was time for another build. Yet again I wanted more power. This is the most current build. Engine -2.5 block. -Standard bore CP pistons -Eagles Rods -Acl main and rod bearings -Arp Block half bolts -New sti oil pump -2.0 heads -Combustion chambers ported to match 2.5 specs -Ported and Polished Runners -Supertech intake and exhaust valves -standard size -BC 272 cams -Gates timing belt -Cosworth head gaskets -Acessport -Killer B pan and pickup Turbo/Exhaust -ATP gt35r -Gimmick inlet pipe -Perrin Fmic and Piping -Perrin Short ram intake -Tial 44mm wg Open Dump -Megan Racing header. -Custom 3 " turbo back exhaust Fuel -Dw 300lph pump -Dw 1300cc injectors -Perrin fuel rails Drivetrain/Suspension -06 Sti transmission and rear end -Sti rear brakes -DCCD pro controller.(not installed yet ) -Napa high line Struts -Tein S-tech springs -17" Motegi rims. Interior -Autometer oil pressure and boost gauge -Prosport water temp -Aem AFR -Pioneer 7" touch screen -Memphis Speakers all around -Alpine Amp -Kicker 12 " sub I may be forgetting some things. Im looking to get 20k I have well over 30k invested into this car. All the parts put on were purchased new from Maperformance. The head work was also done by them. No test drives unless cash in hand. http://s1124.photobucket.com/albums/l562/chrislehmkuhl/
Its getting tuned on wednesday by Shane. Set up should be around 500 hp and only has 1000 miles on most parts.
