FS: 2011 WRX wheels (set of 4) - $600
Discussion in 'For Sale : Car Parts' started by GNUOJOUNG, Jan 29, 2014.
  1. GNUOJOUNG
    GNUOJOUNG Well-Known Member
    I've got new wheels coming in next week and would like these gone after i transfer my tires over.
    Wheels only - $600
    I'll post pics once i get the wheels off
    Chai lor likes this.
  2. jing123
    jing123 Well-Known Member
    do you have the pictures?
  3. GNUOJOUNG
  4. GNUOJOUNG
    rest of the wheels are perfect
  5. John Yang
    John Yang Well-Known Member
    would jump on these if they had 5x100
  6. John Yang
    oh wait.. did a little research and maybe it is 5x100.. can you confirm!? if it is, my income tax needs to hurry!
  7. White-wrx
    White-wrx Member
    These are 5x100
  8. GNUOJOUNG
    ditto^ these are 5x100
  9. GNUOJOUNG
  10. GNUOJOUNG
    oops posted 2 of the same wheel...the first wheel is the same as the last one with the red circle.
    here is the final wheel.
  11. XT BOB
    XT BOB Member
    A couple of questions. I have a 2010 FXT and wondering if these would work on my car. What is the rim width, off set and wheel size (17 inch?).
  12. loxx0050
    loxx0050 Well-Known Member
    What are the specs? I am not as familiar with OEM Subaru specs and wanted to know the diamter, width and offset of these rims. Looking to buy right now.
  13. XT BOB
    XT BOB Member
    I checked out the specs.
    2011 WRX wheels 17x8 55 offset
    2010 FXT wheels 17x7 48 offset
    Both have the same bolt pattern 5x100
    The FXT may need a 3mm spacer and your standard lug nuts should work.
    The 5 mm spacers would require loner lug nuts with the thicker spacers.
    What this means is the 55 offset on the WRX wheels is closer to the struts and depending on what tire size you mount it may result in the tires rubbing.
    Nice wheels but I'm out.
  14. loxx0050
    Same here, I will also pass as I have a 2014 OB H6 with the 17x7 also (not sure on the offset but it is same as the 2011 FXT (the +48).
    I won't want a wider rim now because I am looking to put winters on it (narrower is better).
  15. XT BOB
    XT BOB Member
    Give me a call at 218-391-1856.
  16. XT BOB
    XT BOB Member
    Your contact info?
  17. GNUOJOUNG
    you should probably just PM me, but i'll just PM you.
  18. GNUOJOUNG
  19. Kevin Cowabunga
    Kevin Cowabunga New Member
    still got these? whats the offset
  20. GNUOJOUNG
    yes i do still have them. offset is +55
  21. GNUOJOUNG
  22. GNUOJOUNG
  23. AVANG
    AVANG Member
    Just give these to me bro. .. donations are welcomed
    Ryan FailRad likes this.
