No luck. It doesn't fit XT/WRX front brakes. Eric, I'll give the wheel back to you on Friday or Saturday. I guess Sideways is the buyer.
If sideways says no, let me know please. I'm next in line. Are there tires of any sort of shape on these rims? Thanks, ...Paul
Found another source so I won't be needing these. Bump, for a good set of winter rims for your Subaru!
13s for the strip and the snow...smaller diameter= lower gear ratio and lighter weight=more power to the ground...i'll bet your car is slower then another RS of the same eqipment because of the rims
I run 14's in the winter. With 185/70 tires you really don't need to worry about potholes or curbing... Tires are cheaper for 14 inch rims too. I guess that's one nice thing about having small brakes, you can run the small wheels.
