FS: ACT HD Street Clutch/pressure plate
Discussion in 'For Sale : Car Parts' started by Grayguy, Apr 22, 2009.
  1. Grayguy
    Grayguy Well-Known Member
    I bought this for my 98' LGT, but that car is getting returned to stock and I don't need a clutch like this in there. The clutch is VERY slightly used. The car only drove 3 miles (Piddster will back this up...) with it installed, and in that 3 miles, there is only 3-4 stops. You can see in the pictures that the ACT logo is still clearly visible in on the friction surface. ACT is asking close to $600 for the kit. I'd like to get $450 Obo.
  2. Grayguy
    Obo bump!
  3. mke723
    mke723 Well-Known Member
    is this a stage clutch, i.e. stage 1/ stage 2, or is it stock replacement? also will it fit on any other subies? M.Y.?
  4. StatGSR
    StatGSR Well-Known Member
    ^ just curious, what do you think stage 1 or 2 ACTUALLY means?
    and this clutch will fit most NA subys, 90-99 atleast, and probably some newer ones, but i cant say with 100% certainty.
  5. Grayguy
    This is not a stock replacement clutch. I'm not sure what you think a staged clutch is, but this is rated to approximately 300 lbs/ft of torque. It's firmer than stock, but I never drove it enough to really know.
    This "should" fit any NA subie tranny. I'm not sure if it has to be one with a hydro clutch, but I don't see why that will matter.
  6. Deride
    I think the 06-07 wrx's went back to this style clutch too. Flywheels may be different though.
  7. mke723
    not exactly sure what it means myself, but that is how they are marketed, stock/oem, stage one, and stage 2 and so on... i believe its just a name they use to show a diference between the clamp/ holding loads. i was more interested in if he knew so i could do research and compare.
  8. StatGSR
  9. Grayguy
    bumpski for $400?
  10. Grayguy
    Bump! No body has any interest? throw me an offer.
  11. PhilSine
    PhilSine Well-Known Member
    Will fit EJ22E's as well. This is a nice clutch. Very firm with great grabbing power over the stock clutch. I ran the same one on my 98 OBS-T for 1.5 years with no issues whatsoever.
  12. piddster
    This clutch hasn't even been broken in yet.
    Stage numbers for clutches mean absolutely dick.
