FS: Aluminum Driveshaft Shop Driveshaft - WRX/160
Discussion in 'For Sale : Car Parts' started by istoptofly, Nov 25, 2011.
  1. istoptofly
    istoptofly Well-Known Member
    Bought this new from another member on here. After dealing with the clearance issues it turns out it needs balanced, which I did not do, I just pulled it and it's been sitting in my garage all summer. So needing balanced and having a small gouge (from my clearance issues) I figure it should be cheap.
    The black marks are from the sharpie I used to cover the first light scratches so I could see if it still rubbed, those marks are very light, just enough to catch your fingernail on. The one in the pic is twice as deep (credit card thickness) but only 3/4 way around the shaft, nothing the DS shop can't fix while balancing it I'm sure.
    $300
    IMG_20111125_132400.jpg IMG_20111125_132518.jpg IMG_20111125_132409.jpg View attachment 1545 IMG_20111125_132447.jpg
  2. istoptofly
    Balancing is cheap, don't be scared.
  3. Moleness
    Someone here should take his shaft and install it underneath their ride...
  4. istoptofly
    So you're saying someone should buy my shaft and stick it where the sun doesn't shine?
  5. Moleness
    Correct ;)
  6. blackozone
    But your shaft looks so thick. Are you sure it will fit without additional lubrication?
  7. istoptofly
    Definitely a thick shaft, but it will fit if you take your time and work it in slowly.
  8. istoptofly
