FS: APCC Smart Ups Back up Battery
Discussion in 'For Sale : Car Parts' started by tbone, Jul 31, 2005.
  1. tbone
    tbone Well-Known Member
    I got them Brand new from my Factory, I barely use it. I needed room for my space and its got in the way. Now it's sitting there in the corner and collecting dust. This back up battery can also upgraded to a bigger Battery, links to www.apcc.com to get to know this Battery. Also the 1400 series are discontinue is hard to find that kinda model. As you visit in the website, you notice they are not cheap. BO, the winner takes it PICKED UP ONLY. NOTE it's a heavy biatch even it looks small. I don't wanna lift it again, otherwise I'll break my TBONE. BEWARE!!!
    Technical Specifications
    Output
    Output power capacity 1400 VA
    Output power capacity 950 watts
    Max Configurable Power 1400 VA
    Max Configurable Power 950 watts
    Nominal output voltage 120V
    Output Voltage Distortion Less than 5% at full load
    Output Frequency (sync to mains) 47 - 53 Hz for 50 Hz nominal , 57 - 63 Hz for 60 Hz nominal
    Crest Factor up to 5 : 1
    Waveform type Sine wave
    Output Connections (6) NEMA 5-15R
    Input
    Nominal input voltage 120V
    Input frequency 50/60 Hz +/- 3 Hz (auto sensing)
    Input Connection Type NEMA 5-15P
    Cord Length 8 feet ( 2.44 meters )
    Input voltage range for main operations 82 - 144 V
    Input voltage adjustable range for mains operation 75 - 154 V
    Batteries & Runtime
    Battery type Maintenance-free sealed Lead-Acid battery with suspended electrolyte : leakproof
    Replacement battery cartridge RBC24
    RBCâ„¢ Quantity 1
    Typical backup time
    at half load 27.9 minutes (475 Watts)
    Typical backup time
    at full load 7.8 minutes (950 Watts)
    Runtime Chart Smart-UPS
    Communications & Management
    Interface port DB-9 RS-232 , SmartSlot
    Available Smart Slot Interface Quantity 1
    Control panel LED status display with load and battery bar-graphs and On Line : On Battery : Replace Battery : and Overload Indicators
    Audible alarm Alarm when on battery : distinctive low battery alarm : configurable delays
    Emergency Power Off (EPO) Optional
    Surge Protection and Filtering
    Surge energy rating 459 Joules
    Filtering Full time multi-pole noise filtering : 0.3% IEEE surge let-through : zero clamping response time : meets UL 1449
    Physical
    Maximum height 3.50 inches ( 89 mm )
    Maximum width 19.00 inches ( 483 mm )
    Maximum depth 18.00 inches ( 457 mm )
    Rack Height 2 U
    Net weight 63.00 lbs. ( 28.64 kg )
    Shipping Weight 70.20 lbs. ( 31.91 kg )
    Shipping Height 9.88 inches ( 251 mm )
    Shipping Width 23.38 inches ( 594 mm )
    Shipping Depth 23.75 inches ( 603 mm )
    Color Beige
    Environmental
    Operating Environment 0 - 40 °C ( 32 - 104 °F )
    Operating Relative Humidity 0 - 95 %
    Operating Elevation 0-10000 feet ( 0-3000 meters )
    Storage Temperature -15 - 45 °C ( 5 - 113 °F )
    Storage Relative Humidity 0 - 95 %
    Storage Elevation 0-50000 feet ( 0-15000 meters )
    Online thermal dissipation 171 BTU/hr
  2. Substeroo
    Substeroo Well-Known Member
    So, you just leave it plugged in and during normal times it's a surge protector, but if your power goes out you can use it as a battery?
  3. tbone
    of course
