Cleaning out garage and don't need these any more. These are direct bolt on Big brakes for the 93-01 Impreza/legacy and maybe foresters, Or just replacements for your old and worn out brakes. You will need 16in rims to clear. The fronts are "02 WRX setup Pads, Rotors, Rebuilt Dual Piston Calipers and Mounting Brackets with hardware. The rears are 2000-2004 legacy "H6" setup Pads, Rotors, Rebuilt Single piston Calipers and Mounting Brackets with hardware. $200 for each brake setup or $400 for both. This is alot cheaper then going to your local parts store. Please do your research for fitment on your vehicle. Any questions just PM me. Thanks for looking guys!
FYI The pads correspond to the calipers and mounting brackets. The front pads are PD721 Rears pads MX770.
