FS: BU-353 USB GPS Reciever
Discussion in 'For Sale : Car Parts' started by techy101, Jun 10, 2006.
  1. techy101
    techy101 Well-Known Member
    SOLD: BU-353 USB GPS Reciever
    -BU-353 Waterproof WAAS enabled USB GPS, SiRF Star III chipset (New in box) SOLD!!
    This is a high end waterproof magnetic mount GPS reciever from USGlobalSat. I purchased two for a redunt setup for my carputer, but have decided against it. The unit has never been removed from the box, comes complete with software, mounting suction cup, and reciever.
    This unit will work with any PC based GPS program, and is one of the best out on the market. Totally waterproof.
    Features:
    1. SiRF Star III High Performance GPS chipset - WAAS
    2. High sensitivity (Tracking Sensitivity: -159 dBm)
    3. Extremely fast TTFF (Time To First Fix) at low signal level
    4. Support NMEA 0183 data protocol
    5. Built-in SuperCap to reserve system data for rapid satellite acquisition
    6. Built-in patch antenna.
    7. Super-cohesive magnetic for mounting on the car
    8. USB interface connection port.
    9. Waterproof and non-slip on the bottom.
    10. LED indicator for GPS fix or not fix.
    LED OFF: Receiver switch off
    LED ON: No fix, signal searching
    LED Flashing: Position fixed
    Specifications:
    Chipset: SiRF Star III v3.1.1 firmware WAAS Enabled by default
    Frequency: L1, 1575.42 MHz
    C/A code: 1.023 MHz chip rate
    Channels: 20 channel all-in-view tracking
    Accuracy Position: 10 meters, 2D RMS
    ~5 meters, 2D RMS WAAS enabled
    Velocity: 0.1 m/s
    Time: 1us synchronized to GPS time
    [​IMG] [​IMG]
  2. mlgez
    mlgez Well-Known Member
    I would be interested in this. Are you going to be at Firestone tonight? I have been thinking about going.
  3. techy101
    Yeah, I'll be there between 8:30 and 9pm. I'll bring it if you'd like it.
  4. mlgez
    Sounds good. I would like to check it out. Maybe you can bring your working system.
  5. techy101
    Are you planning on buying it tonight? And no I won't have my system. My car's in the shop right now, so the carputer is along with it.
  6. mlgez
    I just might. I am leaving Buffalo here in about 10 minutes.
  7. AspitFire
    is this unit better then my rikiline 6010 unit? is it worth the xtra money?
  8. techy101
    I actually sold it tonight, sorry.
    I haven't had any experience with that unit, but after the four GPS recievers I've used, IMHO this one is by far the best. Here are the listed acquisition times:
    Reacquisition: 0.1 sec., average
    Hot start: 1 sec., average
    Warm start: 38 sec., average
    Cold start: 42 sec., average
    It's also based of the latest GPS chipset (SiRF Star III), and is by far the most accurate one that I've used.
    Here's a link to the manufacturers page about the unit. (these are the same people who make the BU-303)
    http://www.usglobalsat.com/item.asp?itemid=60
  9. mlgez
    This looks great. Thanks again.
