Clutchmasters Fx500 $325 OBO -Used for about 1k miles of break in with my engine/dogbox F1 Flywheel (12lbs) $110 OBO -Used for about 1k miles of break in with my engine/dogbox Pic can be seen behind clutch disk in photo above. 06 3.54 R180 $480 OBO -Used for about 1k miles of break in with my engine/dogbox -Has roughly 36k miles on it total 5 Speed Driveshaft $100 -Used for about 1k miles of break in with my engine/dogbox -Has 16k miles on it total Wrx Slave Cyl $40 -Used for about 1k miles of break in with my engine/dogbox Wrx Master Cyl $100 -Used for about 1k miles of break in with my engine/dogbox 02/03 Wrx Seats Front and Rear (with pass through) $250 OBO R160 Housings $25 "Cleared" 02/03 Bugeye Headlights (pass side has small crack) $85 Wrx Rear axle $40 2004 Sti Lateral Links $85 with sway bar $100 (2) EARLY 2004 Sti FEMALE FRONT axles BRAND NEW, STILL IN BOX. Will work with wrx stubbed transmissions and also can be used to convert male style axle transmissions to the (IMO) easier to remove/install female style. $200 Thor SVR skulls and demons full face helmet with visor $125 OBO HJC full face sport bike style helmet with mohawk $100 Ractive Silver Shift Boot $10 B&M Carbon Fiber Shift knob (wont work with 6 speed's reverse ring) $40 (2) Blue "ebay" catch cans $40 Autometer Ultra-lite 2 Boost (0-35), EGT(0-1600), Oil Pres (0-100) All 270 degree sweeps $200 Help me clear out my storage!
They are in VERY good shape. i will have to make a run to the garage they are in and get a pic or two. BUMP.
Not sure which axles are being discussed here, as the seller has two front axles and one rear axle. The front axles, left and right are the same. The WRX rear axles are not the same. The left and right are different. Left side has one marking on the axle shaft and is 10 mm shorter than the right side. The right side has two markings on the shaft. ~Dan
pm returned. It takes a bit of getting used to, you can slip it once you do get used to it and it grabs VERY nicely. I may eventually run it again if i go back to a 5 speed. It will work with a 6 speed, im not running it with mine as i got an exedy twin disk with my swap. Fobia also ran a fx500 clutch in his sti at one point. pm returned. I think you have my number, text or pm me and make an offer. i MIGHT be willing to seperate them.
