I have an Aeromotive FPR with Autometer electric fuel pressure guage and sensor. It has the bolt on AN fitting for the fuel rail and braided AN line between. It's a direct bolt in for a 1g DSM. My guess is that it's the same for a 2g. Since it's all universal, you can discard the hoses and make your own. Asking $175 firm. Derek
Is it similar or the same as the A1000-6 injected bypass regulator? Much of it looks the the same, with a slightly different body. If so, someone could pick this up for their scoob for cheap compared to new.
Model 15402 Fuel Pressure Regulator EFI Pressure Regulator Relief Pressure Adjustment Range: 35-90 psi (atmospheric reference) Maximum Relief Flow Capacity: 3.0 GPM Inlet/Outlet Port Size 2x AN-10 (O-Ring Seal) Return Port Size AN-6 (O-Ring Seal)
Looking more closely, the fuel rail adapter may fit a Subaru as well as a DSM based on this... http://cgi.ebay.com/ebaymotors/Fuel...e46QQitemZ310164405830QQptZRaceQ5fCarQ5fParts
