FS: H&R Springs, Wrx Struts
Discussion in 'For Sale : Car Parts' started by devildevil, Apr 2, 2010.
  1. devildevil
    devildevil Well-Known Member
  2. TheSnowman
    TheSnowman Well-Known Member
    so struts and springs are seperate correct?? if so im very interested in the springs!
  3. unhguy78
    unhguy78 Well-Known Member
    will this fit an 06 wrx? and what parts will i need to put them on?
  4. Rusty
    Rusty Member
    i think that replacing springs is pretty difficult because you need a tool to compress them, and compressed springs that can support a car have a s$%# load of potential energy in them. if so your going to have to let a pro do them, for safety's sake. (i think, someone please correct me if i'm wrong, for all i know the springs may not need to be compressed when installing them on Subaru's.)
    out side of that looks like a great deal! GLWS!
  5. idget
    Actually, the stock springs aren't too horribly compressed (not like a honda accord or something)
    Also, a lot of aftermarket lowering springs (depending on spring length) don't require a spring compressor to install. You usually just need to compress the rear springs half an inch or so to get the top nut started. Last set of HR springs I installed didn't require spring compressors, but I'm not sure if these are the same ones as the ones I installed.
    If you do need spring compressors, most auto parts stores have them for rent. Otherwise I think I bought mine from Sears for $40.
    Anyway, glws. How many miles on the struts?
  6. Rusty
    Rusty Member
    ^^^ Thanks for the clarification! :woot: to learning! hahahahaha
  7. SeanWilke
    SeanWilke Well-Known Member
    What year are these off of and how many miles are on them?
  8. TheSnowman
    you have a pm
  9. devildevil
    off an 02, the springs have about 1k miles on them, and the struts were bought by the previous owner right about 4500 miles before i bought the car and i put 12k on them before my build and then about another 1k miles after my build. I have spring compressors, i put this setup together, i have taken others apart, just keep them aimed away from your face incase they let go for some reason. :)
    pm's returned.
  10. devildevil
    Also, i am in duluth.... I can meet in hinkley for a sale.
