FS: Koni suspension for 08+ Forester
Discussion in 'For Sale : Car Parts' started by 03subyR, Jun 27, 2013.
  1. 03subyR
    03subyR Well-Known Member
    Selling complete assembled suspension for Forester 08-13. Comes with 2011 WRX donor struts with Koni inserts and WRX OEM springs. This drops Forester about 1.5-2" but still have plenty of clearance. Spacers can be removed for an additional drop. See picture below as an example of a ride hight. This is the best upgrade for Forester I ever made. $500 obi IMG_0064.JPG IMG_0065.JPG IMG_0066.JPG IMG_0067.JPG IMG_0068.JPG IMG_0043.jpg
    View attachment 8107 IMG_0064.JPG IMG_0065.JPG IMG_0066.JPG IMG_0067.JPG IMG_0068.JPG
  2. predavore
    predavore Well-Known Member
    How many miles are on these?
  3. xluben
    These are very tempting...
  4. 03subyR
    Not sure on donor struts but for Koni about $10K miles.
  5. Mike
    Mike Well-Known Member
    i was gonna say if anyone was gonna jump on this...
    buys a subaru and says i'm not going to mod it...said no one ever
  6. 03subyR
    Can be used on 08+WRX if spacers are removed.
  7. SurlyOldManMN
    hehe... so tempted to pick these up with an exhaust and "surprise" the mrs.
  8. xluben
  9. Curry
    Curry Well-Known Member
    The donors had 25k on them before the inserts were installed. Also, the fronts will not work on 08-10 wrx's because of the difference between the GH and GR suspension geometry.
  10. xluben
    What doesn't work about putting 2011 front struts on an 08-10 chassis?
  11. Curry
    Well you can but you'll have higher front end and positive camber.
  12. xluben
    OK, I agree that the front end will sit close to 1/2" higher than the 08-10 struts.
    But you shouldn't have positive camber. You'll have around 1/2 deg less negative camber, but you should still be able to get within stock specs (or possibly even more negative camber if you'd like).
    I have my Forester (08-10 style geometry) on 2011 struts and I just got aligned today. All are within OEM 2011 WRX specs. None are positive.
    You won't be able to dial in -2.5 deg of camber in the front like I did with my 2011 WRX on 08-10 struts, but you should still be able to get to at least -1.5 deg, maybe even -2 deg.
  13. 03subyR
    Bump.
  14. 03subyR
    Bump. Can fit 2011+ WRX without spacers for the stock ride hight.
  15. xluben
    Want to part out the rear spacers and studs?
  16. 03subyR
    Not yet, but it's a posibility.
  17. kvang
    kvang Well-Known Member
    To confirm these are for 09+(sh) foresters.
  18. 03subyR
    That's correct.
  19. 03subyR
    Spacers removed, now it fits 2011+
  20. 03subyR
    WRX. Just need to replace original studs or swap original top hats.
  21. boone1186
    boone1186 Active Member
    Dayum good deal! Someone snatch these up.
  22. 03subyR
    Pending sale.
