SOLD: Krank Vents (mini) Sold... I have a set of Krank Vents for sale. They are the mini version of the original. Same performance, just smaller in size. http://www.et-performance.com/turbo.html I paid $110 plus shipping, asking $75 obo. Thanks, Derek
These things help seal up rings and remove pressure built up from the PCV allowing boost into the crank case. Here's how the website describes them.... AT IDLE w/ BOOSTED & NORMALLY ASPIRATED (NA) ENGINES: The small KV, with 3/8†hose barbs, acts as if not present (open). The larger KV, with 1/2" hose barbs, is normally closed at idle except to release high-pressure crank case pulses & builds the crank case vacuum, along with the high intake manifold vacuum w/ throttle closed. ON BOOST: The small KV closes & blocks the boost from entering the crank case. The large KV continues to build/maintain crank case vacuum! Air/fuel mixture is blocked from entering crank case. The small KV will contain well over 75 lbs of boost! Go for it! Oil & fuel is no longer blown into intercoolers, intake tracks, fouling plugs & blowing clouds of oil out the exhaust, & popping dipsticks! You know the scenario! NORMALLY ASPIRATED engines benefit even though boost is not present! The crank case vacuum produced greatly increases engine efficiency, piston ring seal, performance, & lowers emissions.
Well, of course, they are sold by a PH.D! :roll: Who the hell cares he is a PH.D? Sorry for the hijack....
