SOLD Purchased this a while ago, forgot I had it and now re-selling. This item is brand new but box has been opened for inspection. Manufacture description...... HYBRID FULL ELECTRONIC BOOST CONTROLLER Size: 40mm x 80mm specially design for: WRX, Nissan GTS, GTR, MR2, Starlet, 300zx, RX7, Supra, any car with and without map sensor. New added Cool "Over boost function" You are now not only have free in cabin adjustments for high boost and low boost setting but also you can wire up to an external switch for adding 10% more extra boost , that means 3 settings!. e.g. if you run on high octane fuel you can take off in low boost to reduce wheel spin, switch to high boost after you get traction then turn on the over boost function before the finish line ! Easy fitting and installation just +, - and signal very compact in size so u can install it virtually anywhere you want in Cabin. This ever popular product is the result of constant refinement on the street and track. Hybrid full electronic boost controller not only spools up the turbo quicker but also regulates the boost accurately. The boost controller kit comes with all the parts you need to install. FULLY ELECTRONIC MCU CONTROLLED ACCURATE BOOST REGULATION FAST SPOOLING REDUCES TURBO LAG HI/LOW BOOST SETTINGS IN CAR ADJUSTMENT OVER BOOST FUNCTION 120PSI USA PRESSURE EQUALISED SOLENOID COMPACT SIZE EASY INSTALLATION CONTROLS INTERNAL/EXTERNAL WASTEGATE OPEN/CLOSE LOOP Here is a link to their website which will have pictures as well. http://www.hybrid-power.com/index.php SOLD Thanks, Dan
