FS: OEM Subwoofer out of a 2008 STI
Discussion in 'For Sale : Car Parts' started by Vampyre, Apr 2, 2011.
  1. Vampyre
    Vampyre Well-Known Member
    Wiring harness is not included. Works and sounds great.
    Asking $50 Local pick up in the Cottage Grove area.
  2. -Ryan-
    -Ryan- Member
    Bloomington
    Is that the under-seat one?
  3. Vampyre
    Yes it goes under the drivers seat and bolts to the right rear leg of the drivers chair.
  4. -Ryan-
    -Ryan- Member
    Bloomington
    Thanks. Do you know how hard it would be to get the harness for it? I'm assuming I'm pre-wired for it. Is that correct?
  5. Vampyre
    The harness plugs into the back of the stock radio then snakes down through the console to under the seat. If you dont have the wire there then it can be bought from a subbie shop most likely.
  6. fancyfootwork15
  7. -Ryan-
    -Ryan- Member
    Bloomington
  8. Frogy
    Frogy Well-Known Member
    Eden Prairie
    It sucks to see people try to sell Subaru parts without the harness pieces, Subaru does not service (sell) most of these items separatly. The connectors used are not commonly used and not easy to get. whoever might buy this could easily spend twice as much as the unit is worth just to get it wired. Clearly the OP here should sell the harness with the item as it will not be usable otherwise.
  9. Vampyre
    I dont have the harness. Dident feel like tearing apart the car before it was sold.
    Im thinking this will go to someone that has a blown/broken sub that has the harness install already.
    New the kit is 270 from subaru.
  10. austinpike
    austinpike Well-Known Member
    Oakdale, MN
    Bummer, it's like 4 screws to get the headunit out and the harness pulls out pretty easily. If there is a chance you could get it from the new owner I'm sure it would help the sale.
    I've actually got an extra harness, but it's only good for 08+ with Nav. (For 08+ the sub kit comes with two harnesses, one for nav and one for non-nav.) So if someone with factory nav wanted to pick up the OP's sub, I'd probably sell the harness for $50.
  11. Vampyre
    SOLD SOLD SOLD!!!! Thanks for looking.
