FRONT: These are the Perrin front anti-sway bar end-links for all 1993-2007 Subaru Impreza (non-STI) I was told, but I can not guarantee fitment so please be sure to verify you are ordering the correct part for your application. These were on my fiancee's 2007 Subaru Impreza WRX Limited sedan for only a few months until we decided to totally change her suspension setup. These add a lot of stiffness to the swaybar linkage and get rid of the soft and flexible stock plastic link with huge rubber bushings. These are practically solid aluminum with only small poly bushings. I'm including all of the required hardware needed for installation. Installation instructions: http://perrinperformance.com/shared/PERRIN/documents/instructions/subaru/pspsus110.pdf REAR: These are the Perrin rear anti-sway bar end-links for all 1993-2007 Subaru Impreza (non-STI). These were on my fiancee's 2007 Subaru Impreza WRX Limited sedan for only a few months until we decided to totally change her suspension setup. These add a lot of stiffness to the swaybar linkage and get rid of the soft and flexible stock plastic link with huge rubber bushings. These are practically solid aluminum with only small poly bushings. I'm including 3 of the 4 stock bolts/washers/nuts; the 4th has damaged threads so I've decided not to include it so you can reuse 1 of your 4. The bushings are still greased and the hardware still has copper anti-seize on it. Installation instructions: http://perrinperformance.com/shared/PERRIN/documents/instructions/subaru/pspsus210.pdf I'm asking $50 for each set! These prices are for local pick-up, but I am willing to ship them if needed. Please email me at [email protected] for fastest response.
