Well, it is already time to part ways with my WRX. Asking price is $8200 or best offer. I have found something I want more and want to sell it to fun buying that. Car is NOT my daily driver, so it will not really get much more miles put on it, and I will NOT be parting out. When and IF it comes to parting, I will take off the parts I wish to sell, and make a post with the items and price for the car. No trades either. Car has 179k on it and I bought the car with about 160k on it, and the motor was completely ran through and rebuilt because it spun a bearing at 155k. So heads were also redone. The only maintanence that I've had to do is the valve cover gaskets which were done a week or 2 ago, fuel filter and the plugs and wires... aside from regular Rotella t6. The only thing the car needs is a front driver side axle which isn't that bad to do and I may even do it myself before it's sold. Car has everything to put ac back in it, I also have all the parts except the reverse threaded nuts for the tensioner bolt, which I will include. Car is tuned for 91 because It used to be my DD, but I usually (90% of the time) ran 93. Now for the fun parts. ENGINE & TRANSMISSION Cobb V2 Accessport Catless up pipe Catless downpipe HKS High Power 3" catback SPT Ram intake Gimmick turbo inlet GrimmSpeed EBCS STI Tmic Tial Y-Pipe SPT Intake Heat Shield Password JDM Radiator shroud Mishimoto Radiator SPT oil cap Mishimoto drain plug Weapon R washer fluid/ coolant reservoir Mishimoto radiator cap Ported intake manifold Mishimoto radiator stays Short shifter Walboro 255 fuel pump GrimmSpeed Alternator Cover GrimmSpeed Coated Turbo Heat Shield Optima Red Top SUSPENSION BC BR coilovers BC rear camber plates Front strut bar Rear camber bolts INTERIOR Cobb white shift knob Dual pillar gauge AEM boost gauge AEM Wideband gauge Weather Tech front mats EXTERIOR Retro fit headlights w/ 5k HID's (will need new kit, may swap out for stock headlights before sale) JDM Impreza badge Debadged Subaru emblem PlastiDipped oem tow hook GrimmSpeed Hood Struts GrimmSpeed Front Plate Delete Custom WRX Vinyl from Montana Strait 35% tint on doors and 15% on the hatch. STATS & FIGURES 220hp on 91 @ DB Performance 240tq on 91 @ DB Performance WHEELS & BRAKES 17x9 Cosmis Racing ZR7 Nexen N5000 215/45/17 Tires Upgrade Performance Ceramic Pads I'm sure there's more I can't remember. I have an AEM wideband new in the box I can include along with an SMY dual gauge dash cluster. Also have a GrimmSpeed crank pulley. Turbo (stock td04) is also newer and in great condition still. Interior of the car is in excellent condition, I'd say 9/10. Only negative is cd player doesn't work just like every other bugeye, but the other functions all work. Exterior is 7 or 8/10. I did a lot of bodywork at school but It isn't perfect. 2 wheels have rash, one is light from bumping a lift leg when backing it out and the other is from mounting the tire since it is a reverse mount and I wasn't aware of that when I mounted the old tires so I had to cut it off and messed up a little. Easily fixable for pretty cheap by "That Wheel Guy". I'm a detailer and my room mates a mechanic so I kept it in as good of shape as possible. Car also is parked in a garage. I'm sure I'm forgetting something but please feel free to comment, pm or text me with any questions at 6125989063. Thanks!
