FS (Roch): "New"/used ACT SB5-HDSS clutch kit w/flywheel
Discussion in 'For Sale : Car Parts' started by dingbang, Oct 31, 2012.
  1. dingbang
    dingbang Member
    Have a newish ACT SB5-HDSS clutch kit with used/resurfaced ACT Streetlight flywheel with 18.5k miles. Should fit 05-09 legacy gt and also 06+ WRX (would check PN compatibility if you have a newer model). I'm asking $700 obo picked up. If you want this shipped, you are responsible for those charges. Speedee delivery would be cheap for shipping.
    What does newish mean?
    Long story short, pressure plate diaphragm cracked and ACT took it in for warranty inspection. Some parts are new, some are like new again, some are used but reconditioned. Giving mnsubaru folks a chance at this before it goes up on legacygt or heaven forbid nasioc.
    Here is a list of what is included.
    ACT SB5-HDSS clutch kit parts:
    SB014 Heavy Duty pressure plate-brand new and fresh off the production line!
    3000502 clutch disc-18.5 miles on the disc, but it was resurfaced by ACT with brand new friction material.
    RB844 throw out bearing-brand new!
    600480 ACT Streetlight LW Flywheel-18.5k miles, was ok'd and resurfaced by ACT. Includes pilot bearing with no issues with same mileage.
    Does not include alignment tool unless I can find it. Can provide used ACT pressure plate bolts/half dozen new OEM pressure plate bolts and used OEM fw bolts with torx plus 50 bolt heads (may have new ones laying around somewhere), if needed.
    This entire kit is usually around 850 brand new. I have impeccable feedback on legacygt under the same username.
    Shoot me a message on here if you are interested. If you are local to Rochester, may be able to lend some elbow grease with the install.
  2. dingbang
    dingbang Member
    bump it, make an offer
  3. dingbang
    dingbang Member
    Bump before for work travel to Cali this week!
  4. dingbang
    dingbang Member
    This is sold, close 'er up!
