FS: Rockford Fosgate 1500w RMS sub amp
Discussion in 'For Sale : Car Parts' started by qstarin, Aug 26, 2009.
  1. qstarin
    qstarin Well-Known Member
    Uptown Mpls
    Rockford Fosgate T1500-1bd
    $400
    Bought it new at Ultimate Electronics near Ridgedale about a year and a half ago. I have the 5 year extended plan on it - the plan is not transferable, but for a member here I would gladly intermediary if the need arose to have the amp serviced while the plan was still in effect. Since that's just my word, I'm not considering it as adding value to the amp.
    Selling cause I don't need two 1500w rms sub amps (have an old PPI in the car right now), and I can use $$ more than I can use an amp in the box in the closet.
    Unfortunately, I don't have the birth sheet any more, but this amp was tested at 1803 watts RMS at 1 ohm when it was produced.
    This is a good amp. It hits harder than my 1400w rms old school PPI amp that's in my car right now. It's in good shape with box and manual. Willing to demo it for a potential buyer.
    Specs:
    # mono subwoofer amplifier
    # 500 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
    # 1,500 watts RMS x 1 at 1 ohm
    # Dynamic Thermal Management cooling system
    # Differential Input circuitry eliminates hum
    # variable low-pass filter (35-250 Hz, 24 dB/octave)
    # subsonic filter (28Hz)
    # variable bass boost (0-18 dB at 45 Hz)
    # optional remote bass boost
    # Class-BD amplifier design
    # MOSFET power and output stages (uses TO-247 MOSFETs)
    # preamp inputs and outputs
    # 1/0-gauge power and ground leads and a 200-amp fuse recommended
    # 14-7/8"W x 2-1/4"H x 8-15/16"D
  2. qstarin
    Uptown Mpls
    bump.
  3. qstarin
    Uptown Mpls
    bump.
  4. qstarin
    Uptown Mpls
    bump.
  5. qstarin
    Uptown Mpls
    bump for some bumps.
  6. qstarin
    Uptown Mpls
    bump.
