All parts are from an engine rebuild at 71,753 miles on a 2009 STI that I purchased new. I can provide pics of anything you request. Let me know if you have any questions, or if I forgot any details. I have no idea how to price any of this stuff, so make an offer if I'm way off. Willing to make a deal for the WHOLE list to go away in one shot. Really, I just want the stuff gone and I hate to throw it away if someone else can use it. Part numbers listed are from the replacement parts on the invoice. Short Block - P/N: 10103AC050 $100 At least one rod bearing has failed, perfect opportunity for a big block project Turbocharger - P/N: 14411AA700 $200 Still worked perfectly Oil Pan - P/N: 11109AA151 $20 Includes strainer/pickup, has some oil residue and bearing debris in it Cam Sprocket - P/N: 13320AA001 $10 Cam Sprocket - P/N: 13321AA001 $10 Cam Sprocket - P/N: 13322AA001 $10 Cam Sprocket - P/N: 13323AA001 $10 Water Pump - P/N: 21111AA240 $10 Air Intake Duct - P/N: 14459AA5101 $10 Vacuum Hoses (8) - FREE Timing Belt Idlers (5) - FREE Timing Belt and A/C Belt - FREE EVERYTHING - $200 But you have to take everything!
Yes, the turbo has the markings "VF48" on it, and the block has not been split, so the internals are just as they were when it was removed from the car, just has all the external items stripped to be used on the new short block. FYI though, jing123 has PM'd me saying he will take everything tonight after work. So unless his plan changes, the lot appears to be spoken for. I will update this thread for sure when anything concrete occurs.
Everything is gone. jing123 nabbed the goods. Next up... 17" winter wheel set... Factory STI BBS rims with good Haaka bologna skins... New thread in a couple weeks when winter is scratching at the door...
