Not sure if anybody here is into RC cars, but figured I'd give it a shot... Team Associated Bullydog 1:8th scale Nitro RC short course truck. I've had this truck for about 3 years now. It's extremely durable and very fast! Every little part on this truck can be replaced so if anything breaks it's not problem to replace. I rarely run it with the body and usually just run it with the roll cage alone, so the body is in very good shape. Another nice feature of this truck is that it can be converted over to electric power with a kit from Team Associated, but nitro power is a lot more fun! Mods: OS Engines 2.8XZ engine. Huge upgrade over the weak stock 2.8 that it comes with. (Ran about a gallon of fuel through the new engine. Lots of life left in this motor and it really wakes the truck up!) Reedy racing pipe Savox 1258TG (Titanium Gear) steering servo - Super fast! Also relocated the stock steering servo to the throttle location for faster response Proline Trencher 1.83x4.35 tires Aftermarket air filter with dust/water guard (several extra filters included) Added a second waterproof box (located next to steering servo.) to relocate the transmitter. There is a 3.6V 5-pack battery powering the whole truck where the original transmitter would normally sit. Upgraded Spektrum DX3C Radio. Improved response time and range greatly The OS engine requires it to be started via a "bump box". There is no pull start or crank that you can turn to start this engine. You put the truck on the bump box and it grips and turns the flywheel to start the motor. Makes for very EASY starting. Slightly used OFNA, dual motor, bump box is included - one of the very best models. Truck will also include basic RC tool kit, nitro fuel jug for easy tank filling, glow plug starter/charger, and a charger to charge the main battery in the truck.I also have 3 gallons of Torco nitro fuel ($30 per gallon) if interested. ...I think that's everything. Let me know of any questions or if you'd like additional pictures. Asking $800. I have quite a bit more invested in it than that! Located in Austin, MN Call/Text - 5zero7 - four3eight - 9two3zero Or email [email protected] Thanks!
