All Items OBO: DTEC: The dtec is currently spliced into the ecu. It will come with everything you need to run and install the dtec, gameboy included. Installing is straightforward and easy....just splice into a few wires and your pretty much good to tune fuel. Selling the setup for $250. Feel free to ask any questions. I will help you install. Used TD04: $80 wrx tmic....I had to saw off the lip that connects to the throttle body. I bought it for 150, will sell for $50 w/o Ypipe 01 rs stock injectors $20 01 rs stock intake system $20 01 rs exedy OEM clutch/pressureplate, around 6-10k on it....just broken in $100
Why re u selling this when i am broke... I need this grrrr Good luck with the sale ill let ya know if i can pic it up from ya
this thing has just about the EASIEST software to tune if you know the basics of tuning. I helped install this and it can be done in about an hour with some help.
it comes with everything you need to make it work a knocklite dtec harness and electronics Gameboy 2 manuals
what exactly is this capable of doing? I did a quick google search but want some info from the person who uses it.
It has some milage on it, about 125k. It worked when I took it off, but It had oil blown through the hot side, so It is safe to say that it needs to be re-built.
