FS:Used CP EJ257/255 Pistons
Discussion in 'For Sale : Car Parts' started by slowrex53, Jun 23, 2009.
  1. slowrex53
    slowrex53 Well-Known Member
    Albertville
    Anybody looking for a set of four standard bore(99.5) CP pistons? With a stock headgasket they will give you a 8.2 compression ratio which is around stock i think. Here is the bad, i had them in a engine for about 500 miles and spun a rod bearing. I ended up just putting a stock short block back in so i made sure i took out the pistons of the damaged block. The skirts have a little scoring on them but you can hardly catch any of the score marks with your finger nail. I have all the pins and clips, but you will need to buy a new ring set which costs just under $100. I would like to see $100.00 for the set of four. If you need anymore info just let me know.
    Thanks
    Brian
  2. Michael48
    Michael48 Member
    Monticello,MN
    Bump 4 good parts/price!
    (Brian did you go back to stock on your motor?)
  3. slowrex53
    Albertville
    Hey Mike, at the time i did. All this happened two years ago. I have Mahle pistons in now. I forgot i left these down in florida and i just got them back. Thanks for the bump!
  4. 2barsti
    2barsti Well-Known Member
    Blaine, MN
    Very tempting.
  5. slowrex53
    Albertville
    I guess im open for offers!
