FS: Used Perrin crank pulley
Discussion in 'For Sale : Car Parts' started by FuJi K, Feb 16, 2010.
  1. FuJi K
    Nuke stole it.
    sold.
    Fuji
  2. piddster
    Does the pulley have a timing mark on it?
  3. asujosh1
    asujosh1 Member
    and it fits?
  4. G_2.5rs
    G_2.5rs Well-Known Member
    ill take it, if youd be willing to help with install..=D
  5. FuJi K
    sale pending
    timing marks that I know of are only the wear on the back side of the pulley from the timing belt. I ran it when I was NA 2.2L, EJ22T swap, EJ22T/EJ205 swap.
    With the engine balancing, I used the stock crank pulley because the Perrin one couldn't be balanced with the crank sprocket, crank, flywheel, & pressure plate. The stock one was spot on during balancing.
    As far as I know, it'll fit and work on All the EJ's up until the '07 Subarus? The newer ones started to run a SINGLE accessory belt so it won't work for that... it might... but I wouldn't recommend it.
  6. piddster
    I asked about the timing mark because with a standalone, a timing mark is needed to set your base timing. We've only found one aftermarket pulley that has a mark.
  7. FuJi K
    ok.... still up for grabs!!!
  8. G_2.5rs
    id still buy it if you'll help with install...=D
  9. Nuke
    Sold!
