FS: WRX dash pod with gauges - SOLD This is the factory optional dash pod for the WRX (bugeyes at least, maybe through 04 or 05?) wit the stock gauges. Gauges are boost, voltage and oil temp. Housing, mounting hardware and gauges are included. Wiring, vacuum hose and oil temp sensor are not. Basically the boost gauge and voltage gauge are very simple to get working, the boost needs a vacuum line run to a T installed in the line at the BOV. The voltage gauge needs only a connection to a +12V key-switched source. Both get their illumination from the dash illumination circuit, which can be tapped into at the clock connection (the pod replaces the clock) or at the stereo harness (where you can also get a key-switched 12V). The oil temp gauge requires the sensor that originally came with the gauge kit. Essentially, for $25 + a few dollars of hose, a vacuum T, and a little wire you get a boost gauge and a voltage gauge. I just bought this, but then ended up with a pod that mounts 52mm gauges, so I'm asking what I paid for it. It's dusty in the picture, but in great shape.
I would be willing to trade for a little exhaust welding work too... Need a new cat welded into a 3" SS TBE and maybe a new flex joint on the downpipe too.
Yes Nathan I am. Ive got a want to buy thread because these things tend to go quick and i'm never at the computer at the right time!! But I would also be interested if no one else was serious though.
Well, the order is WRXBOY2003 tangledupinblu wrxsti_02 wrxjoe I shoulda asked for more $$ Nathan, you get first shot. Let me know if you want it. Needs to be picked up from South Minneapolis evenings or, for an extra $5 I'll put it in the mail.
Sorry, I should look closer (damn similar names and cars!), the list should be: 1. WRXBOY2003 2. 02blubru 3. tangledupinblu 4. wrxsti_02 5. wrxjoe 6. TheWRX As tempting as it is to start a bidding war and take the higher offers I've got (you know who you are ) I'm sticking with the first-come first serve and the price I asked. Nathan, willing to let it go to 02blubru since tangledupinblu isn't actually next on the list?
sorry dude.... I did some work for him like 3 weeks ago and he was tlakign about a guage setup... I was wanting it but then decided I have other ideas, but was working a deal with tangled... and you would have definitely been next for me if 1. I knew you were after them 1. if i hadnt known josh was after them and yada yada... ps = I will still get that hoodie off ya if you aren' too pissed at me kiss kiss...
