hi, i need more information on the fuel pump controller or the fuel pump relay, where is it connected too where can i find it on my car can it be replaced can it be repaired where can i buy it Can it die or malfunction thanks
I believe it may be under the kick panel on the right side... open the door then under the dash where your foot would kick... I believe the fuel relay is under there ???? oh yeah I am talking about the relay
It is connected to the rear wiring harness. It is on the passenger side of the trunk behind the trunk liner. It can be replaced. Probably can't be repaired. A dealership. It can die, but it doesn't happen very often.
That is a really bad idea. If your controller is bad, it's probably due to a short. If it is dead and you hook up someone else's FP controller- it might kill that one as well. Disconnect the one that's in there, check all the connections to make sure they have the voltage, resistance, or ground connection they are supposed to with the key in the "on" position, then try a new FP controller.
