Fuel pump upgrade necessary?
Discussion in 'Modifications And Maintenance' started by tetsusan, Aug 17, 2007.
  1. tetsusan
    tetsusan New Member
    I just loaded Cobb Stage 2 to my '04 FXT last night. So far, it pulls hard and even seems to run/idle smoother.
    Here's my set-up;
    - VF39
    - STi Ecu
    - STi TMIC
    - Individia Uppipe
    - Godspeed downpipe
    - STi axle-back
    I thought that the '04 FXT came with the same pump/injectors as the '04 STi. So I'm wondering if there is any reason to upgrade the fuel pump or am I OK with stock? If upgrade, recommendations?
    -Thanks
  2. Nuke
  3. WRX1
    Nope, he is using the STI ecu, so he will run the sti maps. And a fuel pump is cheap insurance on any car.
  4. webcrawlr
    webcrawlr Well-Known Member
    Only way to tell for sure is a fuel pressure gauge. Like Russ said though, the pump is cheap. If you planned on running a fuel pressure gauge I'd get one (or borrow one). If not go for the pump.
  5. tetsusan
    tetsusan New Member
    Thanks, I'd rather play it safe then and get one. Any recommendations? Walbro 255?
  6. Sogonerg
    Sogonerg Anteater
    walbro 255lp is fine...PM Importimage JOSH...I just did a GB on it...he sells it @ a good price too...
  7. tetsusan
    tetsusan New Member
    Just sent him a PM, thanks for the advice.
  8. Nuke
    ooops, didn't see the sti ecu...all good though :)
