fuel pump
Discussion in 'Modifications And Maintenance' started by Guest, Nov 17, 2005.
  1. Guest
    Online
    Guest Guest
    At what power levels should I upgrade to a walbro high flow fuel pump?
    Thanks.
  2. Steve-o
    when you change injectors.
  3. Guest
    Online
    Guest Guest
    sounds good.
    any rewireing required or modificatins? or is it just a direct drop in?
  4. Guest
    Online
    Guest Guest
    drop in.....
  5. Dream
    Get some modified stockers, talk to Russ (WRX1).
  6. Zola
    Zola Well-Known Member
    Walbro GSS342 is a direct drop in. Lots of people for some reason say to reuse the stock strainer, I did not and have had no issues.
    The Walbro GSS341 can also work with some minor modification I guess.
