Garage clean out ej205 parts
Discussion in 'For Sale : Car Parts' started by Casey, Mar 30, 2016.
  1. Casey
    Casey Member
    Long story short, sold my two bug eyes and have parts to clear out aswell, all parts are best offer, not in a rush just trying to recoupe the money I spent since I have a wedding April 30th.
    I have a full sedan suspension conversion for my old wagon, crossmember, lca's, rack and pinion, 20mm sway bar... Rear latteral links and all four axels in decent shape. $400
    Front and rear stock sway bars off my 02 wagon. $50
    Saggy butt spacers with top hats already mounted with the longer bolts installed for 1/2" lift. $60
    White line front strut tower bar 02-07 $90
    04 Sti wiper motor/transmission assembly $40
    Stock legacy exhaust manifold I was told by previous owner, I'll settle for a 24 pack of coors 16oz brohass
    Ej205 running short block I bought off of a member claimed 130psi across the board sitting on an engine stand since I got it. $450
    Vf34 turbo that's been sitting on my shelf for a 3 years, minimal shaft play previous owner was in the middle of gasket matching it. $400
    2013 Sti injectors 23k on them $160
    02-07 Wrx 3" tbe and up pipe brand new no name exhaust $200
    Wrx wagon rear seat $75
    Wrx wagon washer fluid res $25
    05 sti 20mm rear sway bar with bushings $80
    05 Sti obp rear trunk with wing and wiring in great shape $400
    02-03 wagon driver side taillight in great shape $25
    Passenger side front door card with a couple small tears, $10
    Master switches from an 02 free with purchase of anything else as I think one of the switches were sticky
    02-07 center dash plastic with no ash tray, scuffed up $10
    Stock shifter and linkages from my 02 Wrx $30
    Stock Wrx floor mats that are in okay shape? $10
    02-03 front struts and all four springs, took off because I had a set of tein lowering springs that I thought would be lower and weren't, cannot read what's on it, $40
    Wrx stock 16" wheel with a blizzak on it... Came in the trunk. $20
    Crappy dual 12" bandbass box $10
    I'll keep adding to it as I find stuff shoot me a text for questions 9529929688 thanks
    Also I will be adding photos once I figure out how... Yeah I suck
    phi11 likes this.
  2. LASERBLUE135
    $200 for TBE and up pipe? I'll take that.
  3. Casey
    Casey Member
    shoot me a text when you want to pick it up
  4. LASERBLUE135
    Text sent
  5. Eazy_E_Rich
    Eazy_E_Rich Well-Known Member
    @Casey upload them to imgur.com then put the urls of each image here using the image button.
    Where are you located?
  6. Casey
    Casey Member
    Crystal, mn
  7. Casey
    Casey Member
  8. Casey
    Casey Member
  9. LASERBLUE135
    The brand new exhaust is available (I can't get it now). Looks great!
  10. tangledupinblu
    Dammit i want your trunk!!
  11. dynonacht
    dynonacht Active Member
    pics of floor mats?
  12. dynonacht
    nvm I saw the album, I'll take them.
  13. Casey
    Casey Member
    i offered it to you first! lol you said you were trying to find a white one lol, pending sale right now
  14. Casey
    Casey Member
    they are still availible for the time being
  15. Casey
    Casey Member
    josh, i'm not sure how to edit my first post help a brotha out please :p
    White line front strut tower bar 02-07 SOLD
    Ej205 heads fresh from the machine shop with papers of what was done, still oil'd in the bags will come with half moons $875 firm
    Mitsuboshi timing belt and oem gasket set bnib $360 firm
    Resurfaced flywheel from machine shop ej20 $100
    05 Sti obp rear trunk with wing and wiring in great shape $400 pending pickup
    02-03 sedan front struts and all four springs, took off because I had a set of tein lowering springs that I thought would be lower and weren't, cannot read what's on it, $40
    Perrin light weight crank pulley$ SOLD
  16. dynonacht
    when can I come get them?
  17. Casey
    Casey Member
    7pm today would work probably
  18. dynonacht
    text me 651 338 5599
  19. Casey
    Casey Member
    Floor mats, trunk and strut bar sold
  20. Casey
    Casey Member
    will be around today for anyone interested in anything
  21. Casey
    Casey Member
    exhaust, saggy butt spacers, shift knob sold
  22. Casey
    Casey Member
    Long story short, sold my two bug eyes and have parts to clear out as well, most parts are best offer, not in a rush just trying to recoup the money I spent since I have a wedding April 30th.
    Stock legacy exhaust manifold I was told by previous owner, I'll settle for a 24 pack of coors brohass
    Ej205 running short block I bought off of a member claimed 130psi across the board sitting on an engine stand since I got it. Rotating assembly, oil pick up and oil pan $450
    Ej205 heads fresh from the machine shop with papers of what was done, still oil'd in the bags will come with half moons, cam gears, valve covers $875 firm
    Wrx wagon rear seat has a burn hole in the base $20
    Wrx wagon washer fluid res $20
    02-07 center dash plastic with no ash tray, scuffed up $5
    04 WRX Trunk with Stock wing JBP no dents paint is in good shape, $300
    SOLD ITEMS
    Auto dimming mirror $SOLD
    05 Sti obp rear trunk with wing and wiring in great shape $SOLD
    Stock Wrx floor mats that are in okay shape? $SOLD
    Saggy butt spacers with top hats already mounted with the longer bolts installed for 1/2" lift. $Sold
    02-07 Wrx 3" tbe and up pipe brand new no name exhaust $SOLD
    Kart boy shift knob for a non Sti in great shape $Sold
  23. scoob
    scoob Well-Known Member
    still got front struts ?
  24. Casey
    Casey Member
    Yessir
  25. scoob
    im going to try to come over tonight to pick them up. are those stock springs or aftermarket?
    Casey likes this.
  26. Casey
    Casey Member
    I'm not 100% sure I put teins on and it didn't lower it much if any
  27. scoob
    ok I wont be able to make it today so lets shoot for tomorrow
  28. Casey
    Casey Member
    Okay
  29. Casey
    Casey Member
  30. Casey
    Casey Member
    Updating the main post constantly.
    SOLD ITEMS
  31. Casey
    Casey Member
  32. JonO
    JonO Member
    This appears to still be available...any idea what year Legacy it's off of? Looking for my 99 LOBW. From a quick google search, fit was the same thru 2003 and appears to be the same for sedan/wagon. I'm interested. Could meet most nights of the week after 7pm
  33. JonO
    JonO Member
    Forgot to ask is it pretty rust free? IE no holes, will last for a handful of years before rusting thru. Pics kept causing my browser to take a crap.
  34. Casey
    Casey Member
    Looks to be a great shape
  35. JonO
    JonO Member
    As long as it is "the shape" that fits my 99 LOBW, I'll take it :thumbup: PM coming
  36. Casey
    Casey Member
    its in decent shape for a stock manifold. everything else is still here. shoot me a text
  37. Casey
    Casey Member
    leggy mani sold, Got an 05 sti manifold that needs to be plugged or a bung welded on for egt. FREE with purchase of catless up pipe for $75 :p
  38. spudd
    spudd Well-Known Member
    Sti rear bar still available?
    Casey likes this.
  39. Casey
    Casey Member
    Vf34 sold, Sti sway bars are available
  40. Casey
    Casey Member
    turbo and rear seat sold, got a catless up pipe for $50
  41. Casey
    Casey Member
    Tactrix 2.0 with cord $100- what I paid
  42. Just-someone
    Just-someone Well-Known Member
    Heads still available? What's done to em ?
  43. Casey
    Casey Member
    There's a picture of the receipt on imigur on the first page, fresh rebuild, pressure tested. They're still oiled in the bags from the machine shop
  44. NastyLeggySS
  45. Casey
    Casey Member
    Still available, a lot of interest but cash is king, supposed to meet up with somone on Friday
