1. '02 WRX stock struts. These have 150k miles on them but are not blown. Most of the miles were freeway so that is my guess why they still worked. Would make good cores for some Konis. $8 http://www.tc.umn.edu/~deba0016/4SALE/IMG_1978s.jpg 2. Rear WRX rotors and caliper brackets. I did the H6 upgrade and have this leftover. $5 http://www.tc.umn.edu/~deba0016/4SALE/IMG_1980s.jpg 3. 2.5RS Turbo kit leftovers. IC, tubes, flanges, hose clamps, EM box, wiring, valve cover tapped for oil return. SOLD 4. '02 WRX Thule roof rack bars, mounting feet, and fit kit. This works with all Imprezas 93-07. I cut the bars so they are as short as possible. SOLD! 5. STI cluster Surround $2 http://www.tc.umn.edu/~deba0016/4SALE/IMG_0775.jpg 6. A/C Compressor and high pressure hose. 19k miles from '04 Baja Turbo may fit other just never researched it. $10 http://www.tc.umn.edu/~deba0016/4SALE/IMG_0762.jpg 7. PS reservoir FREE http://www.tc.umn.edu/~deba0016/4SALE/IMG_0757.jpg 8. 2002 WRX A/C hard and flex Lines and Condensor. Came from a working A/C system: SOLD 9. '04 Baja Turbo Driveshaft (WRX Driveshaft pictured above baja turbo driveshaft in picture) 19k miles. One side could be shortened by a driveshaft shop and it used on a WRX, or you could use everything from the center support bearing forward as a direct replacement for a WRX. $10 http://survey.micro.umn.edu/~chad/Subaru Swap/Day2/IMG_2104.jpg Email me: [email protected] Or PM me. Parts are all in South Minneapolis. I can ship at your expense if you don't want to pick stuff up.
Iam thinking about taking the struts. mine are soooo shot right now that it just sucks and i dont have a lot of money to get upgrades so i think i will take them.
Sounds good, they should work well for you. The only reason i removed them was to get something adjustable for autox. PM when you want to meet up.
