Garage Heater Q
Discussion in 'Off-Topic' started by ej20, Dec 8, 2009.
  1. ej20
    ej20 Well-Known Member
    Sorry if this is stupid but i "do" want to know. I never used these type before and dont know how they work. How does this type of Garage Heater work? Tell me everything you guys know about it such as what does it run on, does it need electricity, etc... I hate my current electric one that I just bought so I'm looking into one of these type. Need to heat up a 2 Car Garage.
    This type of Garage Heater.
  2. RichWRX
    RichWRX Well-Known Member
    Orr,Mn
    looks like that one is kerosene, yes it needs power to run. And they are real stinks and use up alot of oxygen.your eyes will be burning after it runs for a few minuites
  3. SubeN'Siren
    SubeN'Siren Well-Known Member
    Siren, WI
    Blows most electric ones out of the water as far as providing real heat though.
  4. ej20
    Is it worth getting one(used)?
    or whats my best option? Willing to spend around $200. New or use is ok. I really want one of those shop ones that require hardwiring but currently I need it this winter and dont want to spent alot of money, yet. only gonna use it maybe once/twice a month.
  5. errorcode3
    errorcode3 Member
    Hutchinson, MN
    you know what i think i have one out at my parents place, unsure how well it works since i haven't used in a long long long time, i would sell it for dirt cheap.
  6. SubeN'Siren
    Siren, WI
    I'd weigh the options first, these do throw a lot of heat, but as mentioned, the kerosene fumes can be a little overpowering.
  7. Scuba Steve
    In the Co-Driver Seat
    I have a 35000btu propane heater and it works fine for my garage (2 car garage). 50 degrees inside while it's 0 outside...
  8. ofspunk7
    Nord' St Paul
    Yeah it is a really good idea to vent your area if you are going to use something like this. That is going to be your problem... using up all of your clean air. So think about how can you vent clean air in without loosing all of your heat.
    Good Luck
  9. dmoo
    dmoo Well-Known Member
    the iron range
  10. 95lwrx
    95lwrx Well-Known Member
    brainerd
  11. ofspunk7
    Nord' St Paul
    yeah we used a sunflower heater very similar to this in the last house i lived in. it works. no smell. plus you can just use the tank from the grill as stated above instead of dealing with a different fuel source.
  12. mrrhode04
    mrrhode04 Well-Known Member
    Coon Rapids
    I just got a friend a propane heater for christmas but it is like the heater that the op posted. It is a 35,000 BTU heater plenty for a two car garage.
  13. pksublime
    pksublime Well-Known Member
    very interested in people recommendations on this topic
  14. PaulasaurusREX
    Rogers
    Electric heater
    I have an electric Farenheat heater mounted to the ceiling in my garage and have been more than happy with it over the past 2 years. My garage and front and back garage doors are all insulated which helps out greatly.
  15. zyklon
    zyklon Well-Known Member
    Eagan
    I used a loaned propane heater last week for the first time. Worked pretty well in my 2-car.
    What exactly are the risks and considerations with using one of the small LP heaters? I know they exhaust CO, which hangs low, and they burn up available oxygen. Is cracking the garage door a few inches enough for a couple hours of work in the garage?
  16. yarpirate
    yarpirate BANNED
    Sorry if this is a derail, but I think it's in the same vein.
    If I'd get something electric, how much would I have to spend to keep an uninsulated 2 car garage above 10 degrees? I'm not looking to work in the garage specifically, but I'd like it if the car would start a bit better, without struggling so hard.
    Secondly: Would it be better to just get a block heater? How much do these run for, and how difficult is the installation? [I've never had one installed in a car before, they've always come standard. STis don't offer it as standard kit, I guess.] Car is an 05 STi - I've found block heaters for Imprezas that specifically state "Non-WRX only."
    Any help would be appreciated. :)
  17. RichWRX
    Orr,Mn
    I have the exact heater, works great. I have infloor heat and use it to bring the temp back up.
  18. PaulasaurusREX
    Rogers
    That must be soooo nice. Every time I have to get under the car I wish my floor was heated.
    I need a lift :biggrin:
  19. idget
    falcon heights
    Yes, this is a threadjack and yes this is what a block heater is for. Easy install. Drain coolant, pull block plug, install block heater, route cord, then refill coolant.
    I need a real ceiling and insulated garage doors before I think about wasting more money on propane or electricity this winter. For the time being, halogen lights, a small mr heater (thanks Lexi!), and a jacket do the trick for my detached 2-stall.
  20. PaulasaurusREX
    Rogers
    Can't help ya with cost, I only turn mine on when I need to be in the garage. I'm not rich enough to afford keeping my garage warm all winter unfortunately. However I can say if I use the heater for a full day I can notice a couple bucks here and there on the bill. I'd say go block heater over running an electric heater all winter. Especially if your garage is not insulated.
    If you have the $$$ i'd suggest at least insulating your ceiling, that would help tons with keeping the heat in.
  21. dmoo
    the iron range
    i will de rail with you.
    https://www.chaplinssubarugenuineparts.com/product_info.php?products_id=65
    i just put this on my 04 STI works unbelievably well. starts with no hesitation. I park out side every night and the heat inside the car warms up very quick because the coolant is well on its way to being up to temp.
    i installed it myself fairly quickly. im sure someone on here (me, depending on where you live and times etc...) could help you or do it for you if you
    wanted
    -Dan
  22. yarpirate
    yarpirate BANNED
    Thanks for all the info :)
    Sorry again for bringing thread off topic. Nothing to see here!
  23. WRX1
    Over there
    The other thing to keep in mind is the stock battery sucks ass. 300cca. The one in my new forester is going to be replaced shorty. 10 degrees outside and it cranks slow. No point in going to the dealership, they are going to throw another craptastic battery in it.
    Ej20, YOU need to decide what your plans are. If you plan on installing something better later on, just go with the propane heater.
    http://www.northerntool.com/webapp/w...2713_200332713
    It is small, portable and works. It will save you money until you can install a real/better heater. If you plan on keeping this as your heat source for years to come, you better up your budget and get something half-assed decent. No point in spending $200 on something that is only going to last a year or 2 then add on the cost of kerosene and such.
    Personally, I am running the single version of the heater I linked above. Anf for now, it works. Most of my garage is insulated (all the walls), but I need to insulate the attic. Of course, I need a job so I can finish all the other items before I blow in insulation.
  24. mrrhode04
    Coon Rapids
  25. ofspunk7
    Nord' St Paul
    If it is your garage. insulation would be my first investment. this will keep a lot of heat in (from the car engine and house heat) and a lot of cold out. Doing this alone will make a good difference in the temp. From there i would get a permanent heater. Like russ said don't spend $200 on something + fuel. Do this like you would your car. Make the right steps and do it as a process. This time of year is great for the attic work because it isn't deathly hot. insulation isn't too expensive and you get a tax credit for it (talk to your tax person). it is easy to install (the rolls) and should be a few hours (or one) work, at the most.
  26. Vector
    Vector Rally Organizer
    Yeah, cost of insulation to put int he walls is probably less than the extra cost of heating it without . . . AND you can get a smaller heater.
    I have an oversized 2-car garage 24'x24'. R19 in the walls, R36 in the ceiling, and the doors (2 9'x7') are R10-ish (don't 'zactly remember). Two 36"x60" windows. I actually had an HVAC professional do a heat calc and it ended up like 38,000btu, so I ended up with a 45,000btu heater.
    Typically I keep the garage at 45F, but I can crank it up to 70F in the dead of winter when it's -20F out and it's nice and comfy :)
  27. Vector
    Also, if using a free-standing heater, keep in mind the potential for oxygen depletion. Many heaters will have an oxygen depletion sensor and shut down if it gets too low, but not all . . .
    Too little oxygen is no better than too much carbon monoxide.
  28. ofspunk7
    Nord' St Paul
    to add to that... then you have to crack the garage door to get in breathable air and then you loose all of your heat. if you are trying to just keep it warm for your cars the expense for keeping it heated will be too high with a portable unit.
