Garrett 3076 Vband(5000miles), Hand-fabbed T3 turbo kit, Avo Tmic
Discussion in 'For Sale : Car Parts' started by Tdagen, Nov 2, 2009.
  1. Tdagen
    Tdagen Well-Known Member
    ALL these parts ARE for sale...
    I have a feeler going out here parts are still on the car but I am upgrading to a 40r-42r Twinscroll so I need to get rid of these goodies!!
    Heres what I have:
    Garrett 3076 .82 T3 with V-band exhaust side, 5000 miles on it pretty much only boosted to about 21.5 psi , I just finally turned it up to 24psi last weekend :devil:...
    Garrett 3076 .82 Vband-$1000 turbo comes with thermo-tec Heat wrap on too...
    Next up is the Hand fabricated T3 setup I made.( It will come with the up pipe w V band 38mm wastegate flange, V-band down pipe 2 A/f sensor bungs, turbo to TMIC pipe W/boost reference, silicone to hook turbo to tmic pipe, used T3 gasket, and dump tube. The only things you will need to make the pipes work is the turbo above, an intake of some sort, and a tial 38mm Vband wastegate....The kit is not perfect I made it when I had the 5mt so when I got the 6mt I found out the downpipe sits about 1/2 inch away from the transmission, its not a big deal it just band against the 6mt if your chassis flex's the right way lol... I have been running it all summer loving the kit to tell you the truth. I will put up a Airboy road dyno here from last weekend just to show it performs...
    Handfabbed T3 turbo kit $300
    up pipe 2.2inch inside diameter...:devil:
    Tial 38mm ewg flange & welds
    One of the bungs on the downpipe
    turbo to tmic tube W boost reference
    More ...vvv
  2. Tdagen
    Here is a pic of the turbo to tmic pipe before I welded on the boost reference, This tube is now wrapped in thermo-tec heat sheild
    Next up is an AVO Tmic it has about 17,000 miles on it never drove in winter(garaged) or anything.... Its also wrapped in the thermo tec heat sheild. The only problem with this TMIC is one of the BPV bolts stripped out and I had to re tap/Re-thread it, resulting in one of the bolts being bigger than the BPV bolt-hole ... All you have to do is drill the BPV hole a little bigger to fit the bolt, works better than new... I have logs to prove it spools fast and holds boost perfect... I personally love this TMIC it is QUALITY , It flows 60 # per min ( check unabombers TMIC Faq ) This TMIC is off my 2002 wrx but I think it is interchangable up to 07 wrx/sti's
    The only reason I am even getting rid of it is because my turbo is going to outflow the TMIC...
    Retail is $800 I can do it for $400
    BTW None of these parts have seen winter or rain hardly for that matter....Car is garaged all winter
    Airboy roaddyno @ 24psi last weekend..
  3. Tdagen
    Just bought this turbo in spring basically new still have the original packaging...
  4. Moleness
    Nice setup, nice price. I may take it if you still have it in 4 months, lol. ;)
  5. Nuke
    It'll be very very similar to what you rode in
  6. Tdagen
    I actually have to get rid of it right now because I need the money , so I am hoping someone will want it soon....
    I am thinking about also getting rid of my T1 ID bosch 1000cc injectors (5000miles)....:(
  7. Shibbs
    What's a literocola?
    Mmmm... liter injectors.
  8. kvang
    kvang Well-Known Member
    If you get rid of injectors PM me please!
