Gauge Pod
Discussion in 'Modifications And Maintenance' started by eroc21, Nov 6, 2006.
  1. eroc21
    Online
    eroc21 Guest
    Hello,
    I was wondering if anyone had any recomendations for gauge pods. I'm not sure if I want a steering column, pillar or dash mount. I was just wondering what you guys had for recomendations or what you have and if you are satisfied with it.
    -Eric
  2. w_o_t_boy
    w_o_t_boy Well-Known Member
    The Autometer piece that replaces the bezel around your dash gauges is nice if you only need two . . .
  3. idget
    Dozens of examples here:
    http://forums.nasioc.com/forums/showthread.php?t=255488&highlight=post+gauge+setup
    I like my autometer bezel. Pretty stock looking and suprisingly perfect fitment. It only has 2 mounting points tho (up top were the 2 factory screws are). It rattled on cold days so I secured it on the bottom. A third gauge will eventually be installed either in the heater vent, or with the subiegal fiberglass pod (fits flush up between the bottom of the a-pillar and the windshield). I think it gets pretty busy with the gauge cluster plus a steering column pod.
    The clock pod was my second choice as its easy to wire and more visible than the gauge cluster location. I personally dont like the a-pillar pods bc of looks, and also I already bump my head getting out of the car enough as it is :)
  4. T-REX5000
    T-REX5000 Well-Known Member
    I love my dash pod. easy to see and replaces in my opinion that ugly clock assy.
  5. SomethingsWrong
    I have a 3 gauge pillar pod. I like it because it keeps my boost and other gauges at eye level where I can watch the needles dance.
    On the downside, I tend to bump it when getting in the car.
    The bezels look good but it seem your view may get blocked alot.
  6. yanwasp
    yanwasp New Member
    I used to have the triple pillar pod but it always seemed to get in the way when makingn tight left turns. Now I have a triple gauge dash pod I purchased on ebay from a guy in burnsville.
  7. Zombie
    Zombie Well-Known Member
    I like the wrxtra.com pod for its stock appearance. Be advised though as one member got his car broken into presumably because of his gauges. I hid mine.
  8. evilrex
    evilrex New Member
    take a look at rallysportdirect.com Good selection of pods. I replaced my OE boost gauge with a MB 52 single gauge pod. Fits nice and neat right above the VIN.
