Might be selling these things off. Not sure yet, but if the interest is there I'll probably bite. UR1000cc injectors w/ low impedence resistor box. All 4 injectors, and wiring.
Not sure on a price yet since I'm still not sure I'm selling them. I need to get this fuel pressure gauge installed to make sure it isn't a pressure issue. There isn't anything wrong with the injectors, there is just rumor that they may not like stock ECU voltages. Something something not enough current to run low impedence injectors with resistorpacks. Kelly you'd be fine because I believe the Hydra runs LI injectors without the need for resistor packs.
Depending on price, I might be interested. Edit: errrr UR is showing 2 different setup's for the WRX and STi........must be different...
It's different because WRX injectors are top feed, STi is sidefeed. You would need top feed rails and WRX TGVs
