These are the V2 DMS 40mm coil overs. They are single adjustable for rebound. The adjusters for damping move freely and the indents are very clear when turning the adjuster. Current springs are 300 lb/in front progressive springs and 335 lb/in non-progressive rear. I have some other springs as well, but I'm not sure of teh rate. The current springs are about as stiff as these coil overs can handle. These are in need of a rebuild as I have been using them for 4 years without any problems, and have regreased them twice in that time. The adjustable collars for adjusting ride height move freely. The rears will come with stock GC tophats, the front come without tophats. These are in good condition, I just want to go to something much stiffer for autoX use. $800 OBO
Not even close.:biggrin: I'm looking at a Koni setup with a Ground Control sleeve and spring. 525-550 front springs with 600 or so rear springs. With the V710's I'm going to be running next year I will need higher spring rates to keep body roll to acceptable levels. My car should be less than 2500 lbs next year as well, so that helps a little.
