I have a 2.0 shortblock that's taking up some space and was wondering if anyone needed it. There was nothing wrong with it when pulled, it just has 151,000 on it. There was no lower end noise at all. Would be perfect for a quick and easy rebuild or if you desperately need a running short block. $375 I also have the heads, RH side is fine, LH side cylinder 2 has burnt exhaust valve, they come with the cams and shimmed lifters but no valve covers as the heads I purchased came with broken covers so I needed to reuse the old ones. $225 for these. I also have a Megan Racing UEL 4-1 header with up pipe for sale. It didn't fit my application. It's coated with some sort of black paint/powdercoat. $125
