GI/FS 2000 RS coupe 5 speed
Discussion in 'For Sale : Car Parts' started by richard donovan, Nov 7, 2008.
  1. richard donovan
    richard donovan Well-Known Member
    I’m considering selling my car, I need something bigger with more room and it needs to be more of a highway cruiser not a corner carver, I LOVE THIS CAR. I just need something different.
    Pm me with offers or suggestions thanks for looking
    I'd prefer to sell it all together first
    I'm looking for a Legacy wagon 2000 or newer (auto or manual)
    Pictures next post
    2000 Subaru Impreza RS coupe 5-speed 203,XXX miles
    Primer hood and front fenders (hit deer passenger side had a dent on the driver’s side fender so I replaced it at same time, I have pictures of the damaged fender and hood)
    Surface rust on rear wheel well lip
    Surface rust around front of sun roof
    Some scratches and small dents
    Scratched in bumpers front and rear
    Dent in passenger side quarter panel behind door and in front of wheel well
    The car drives wonderfully, very tight and responsive even with stock springs (I have Prodrive P1’s not installed, I can install before sale with requested struts if needed)
    This car would be perfect for an I-Speed re-flashed ECU ($400)
    Engine
    Short block with 40,000 miles
    New head gasket 3,000 miles ago
    New Timing belt, cam seals, crank seals, timing belt pulleys, valve cover gaskets
    New Water pump
    Delta 2000 grind cams hot cams
    Grimm Speed Thermal intake spacers
    Perrin light weight crank pulley
    Short ram intake cone style filter (and stock)
    New plugs 400 miles ago
    Paranoid grounding kit (not installed)
    Re-surfaced heads when assembled
    Engine block heater
    Grp. N Engine mounts
    Grp. N pitch mount
    Exhaust
    Borla Header
    2 1/4 “cat back with turbo flow style muffler and stainless tip (made and installed wed the 5th)
    Suspension
    Prodrive red P1 Springs (not installed-can install for sale and put in requested struts too)
    Perrin adj. rear sway bar with heavy frame mounts
    Perrin alum. spherical bearing sway bar end links
    Energy Suspension sway bar bushings (bigger than stock Perrin parts)
    Grp. N strut top mounts
    Grp. N Rear suspension bushings FULL SET (not installed)
    White line Front sway bar bushings
    White line Steering rack bushings
    White line Anti-Lift kit
    White line rear out rigger bushings
    Hairpin Racing Front strut bar
    Trans
    Rebuilt 1,000 mile ago by Subaru mechanic ((new fifth gear and synchros) and center diff with 60,000 miles new rear seal and seal kit installed)
    Kart boy short shifter arm
    Kart boy rear shifter mount
    New clutch 3,000 miles
    Trans throwout bearing sleeve
    Re-machined flywheel
    Grp. N Trans mount
    Brakes
    GoodRidge Steel braided brake lines
    Carbotech Brake pads (not installed)
    OEM WRX front brake caliper brackets (not installed) (just need rear legacy wagon brackets to do a full brake upgrade)
    Wheels
    STi 2004- Gold with good tread
    Stock six spoke bad tread
    Interior
    6 disk cd changer OEM
    Heated front seats (high/Low)
    New speaker through out
    Factory (I think) carbon fiber style trim pieces on dash
    Trunk cargo net
    Extras
    STi key cut to fit all locks and ignition
    Spare trans with around 60,000 miles (center diff in car)
    Spare heads - two sets
    Spare stock cmas - one set
    Spare short block (stock unit 198,000 miles)
    110 watt fog lights in need of paint (wired to factory switch)
    Fog light covers not painted (not installed)
    1998 RS trans blown first gear everything else great
    Things not installed
  2. richard donovan
  3. Squiggly
    Squiggly Squiggly
    nice car! what are u looking to get? i know a few who may be interested.
  4. richard donovan
    I'm looking for a highway cruiser, I don't really want to sell it. I just need more room,
    but with the new exhaust I can't stop driving it around just to hear it rumble :)
  5. Colin
    Colin Well-Known Member
    How much
  6. richard donovan
    I'm gauging the intrest for my car and wondering its value
    I'll be out of town this weekend, I'll still be able to answer pm's just not show the car
  7. twiztid_rs
    twiztid_rs Well-Known Member
    nice car... minus the minimal negatives on it (dent, unpainted hood n fenders)
    this is a damn nice rs. nice start to a mild n/a build and very nice job on the other upgrades...
    good luck on the sale, though i don't think you'll need it...that is if you decide to sell, which you shouldn't....
    on a side note though, how do you like the results of the spicy delta regrind on the cams??? big difference?? i've been considering it for awhile, that is when i'm in my n/a build mind set
  8. richard donovan
    Thank you
    I love the cams!! big difference, but I have more upgrades too the intake and exhaust to help get rid of the burnt gasses. the stock cams have a dead spot around 3,500-3,750 rpm and then die out again around 4,700 rpm with the regrinds and my upgrades the engine pulls hard all the way to 4,000 rpm's and then has another boost of life all the way to 6,500 rpm, its almost scary how fast it goes from 30 mph to 75 mph in 3rd gear.
    Install the cams you'll fall in love with your car again!
    I thought it was easy to do, just need a couple specific tools, and your set
    some people say the short ram takes away from low end torque , well with the cams,header, and cat back the engine produces enough power for city street driving
    hope that answers your question
    Richard
    ps i just saw that your from Rochester, Thats where I'm from. Actually I had 2nd street muffler center do the cat back work for me, they do all my families exhaust work, they are the best in Rochester.
    they know what it takes to get the job done and they don't charge to much for thier work!
  9. xxtraloud
    xxtraloud New Member
    what the heck! you are crazy about this car, I can't believe you are selling it!
    good luck though.
  10. tonyM
    very tempting for my wife to be. although she really wants a forester. I'm gonna show her this when she gets home from work.
  11. richard donovan
    I know, I just don't have the money to get the paint done thats all she needs to be a head turner, it already has the sounds thanks to you and your Borla header :yumyum:
  12. Shibbs
    How about a 2007 WRX? :)
  13. richard donovan
    straight up trade...;)(joke)
    I don't have much cash, if I did I would paint this car and ride off into the sunset
  14. Shibbs
    That's what loans are for!! :laugh:
  15. richard donovan
    Back in town, bump
  16. Ctracey218
    Figure a price yet?
  17. richard donovan
    pm an offer
    * added * almost forgot about the Hair pin racing front strut bar
  18. Ctracey218
    Sent out that PM ; )
  19. 83projectbrat
    83projectbrat New Member
    how much!!!
  20. richard donovan
    I'm going to get some quotes on getting the dent pulled and painted and the figure a price based on that. or get it done.
  21. richard donovan
    the car will be sold as is, no paint so the new buyer can paint it how he or she would like to paint it:cool:
    I bought the car for $5500 and put $8000 in to the car in parts and repairs.
    thats $13500 :emo: take that times 50% = $6750 now as for a realistic price...
    most RS coupes sell for $7000-$8000 in good shape with small mods
    it needs $1500 in paint , subtract that from the avg. normal sale price
    avg. normal sale price is $7500 - $1500(paint) = $6000
    pm me offers
  22. richard donovan
    oh by the way i think $6000 is to much to ask
  23. Shibbs
    Wow. I really wish I could sell my WRX. :(
  24. richard donovan
    wow? is it priced right?
  25. Scuba Steve
    No, i'd prefer to see 1000. then i could afford it. :biggrin:
    GL with the sale
  26. stiv5
    stiv5 Well-Known Member
    I think that you priced your car right due to needing some comestic work. Someone will buy it. Good Luck.
  27. devildevil
    devildevil Well-Known Member
    ill show the gf and see what she says. she's been wanting a new car.
  28. richard donovan
    Thank you for the kind words
    PM me with offers and showing times
    I'm ok with driving to Hudson, WI with enough notice
    ps I was told tonight that a car going 20 mph in fourth gear at 1000 rpms with out the engine shuttering is odd...mmmm torque :biggrin:
  29. qstarin
    Online
    qstarin Well-Known Member
    mmm .... torque. I'm showing this thread to my GF right now. :) She is in the market for a subie.
  30. richard donovan
    craigslist bump
  31. Ronnie@RSmotors
    if it wasn't for the rust spots I'd be all over this.
    As for the price, I think its a lil high for having 203k and needs body work.
    I can't consider the other mods since it would be swapped out anyways.
  32. richard donovan
    Would you like to set up a test drive?
    this car should not be swapped, and if it was to be swapped the parts not used by the swapper would be a great addition to any NA 2.5L car :)
  33. richard donovan
    Car is sold pending pick up on Friday afternoon
    Thanks for the positive response
    I will post if the sale does not go through
    Richard
    you might see alot of parts forsale in the future, help out the buyer :)
  34. Shibbs
    You sure there's no way you'd accept a trade + cash for an 07 WRX? :biggrin:
  35. richard donovan
    I don't have the cash sorry shibbs, I feel bad enough for even letting the car go :( I spent 4 years adding parts in such away to only make it a even more well rounded car than how it was stock. I would like to think that if STi had tuned a NA 2.5L car for the united states it might feel like this one.
    ps. trying to find a car to replace it is going to be very hard!
  36. prezawagon
    prezawagon Well-Known Member
    A lot of parts? ... as in a nicely built 2.5 engine screaming to be swapped into an OBS? :biggrin:
    Anyway, congrats on the pending sale.
  37. richard donovan
    not sure what he'll do with it, i think its fast enough the way it is :biggrin:
  38. greg donovan
    at least gas is cheaper for now so the truck wont bleed you totally dry.
  39. richard donovan
    true, and i can throw my skis in the back , I will miss the heated seats!! but probably not as much as ladies, gigade
    ***Family Guy - Quagmeyer****
  40. Shibbs
    GIGGITY GIGGITY GOO! :laugh:
  41. richard donovan
    the fisrt buyer fall of the face of the earth after getting his loan check from the credit union.... so I showed the car on tue. and he will be getting back to me today or by sunday.(he wants the car buy got busy with work and need to work all week) so as of right now I have no money in hand.
    the car is still forsale,
    more extras found,
    98' rs trans blown first gear
    00' RS trans no center diff
    2 RS short blocks (both in need of rebuild)
    2 sets of heads, one set of stock cams(one set of heads has been steam cleaned and could use a rebuild)
    stock header
    and everything else on the first page
    I'll be in Rochester with the car until sunday afternoon (pm for my number)
    Richard
  42. 93Legacy
    93Legacy Well-Known Member
    Do you know roughly what your wanting to sell it for? love the body style of the rs.
  43. 93Legacy
    nevermind found it, not to bad of a price a have seen alot less go for more. but still interested, my legacy is on its last limb of life and i wont buy another car but a subaru!
  44. richard donovan
    I have a new buyer and he said he'll be picking up the car this week , I'll post when he does the money switch,
    93legacy thanks for the kind words
  45. richard donovan
    buyer # 2 backed out.
    the car is still for sale.
    $6000 or best offer, its in Rochester in a heated shop just chill'n waiting for a new owner to love it and care for it.
    everything goes with the car
    pm me with offers/test drive times
