GI/FS: 2008+ Progress Springs for WRX
Discussion in 'For Sale : Car Parts' started by predavore, May 27, 2010.
  1. predavore
    predavore Well-Known Member
    SOLD!!!!!!!!!
    http://www.newedgeperformance.com/progresssportspringsfor2008subaruwrxnon-sti.aspx
    (I want to know why they say it's not for the STi since I'm running STi pink springs on my car now.)
    Detailed Description
    The Progress Group, Inc. has developed new Sport lowering springs for the new platform used on the 2008 Subaru WRX. This Sport Spring set will lower your 2008+ WRX approximately 1.3 inches in the front and .8 inches in the rear (Your actual drop may vary due to options, etc.)
    Improve handling by lowering the center of gravity and increasing the spring rate. Improves the looks of your 2008 WRX by giving it more of a Tarmac Rally look! The springs are cold wound, shot peened, load tested, and include a lifetime warranty.
    Will NOT fit the 2008 STi!!!! For 2008 WRX ONLY!
  2. JasonoJordan
    i have a set of stock bumpstops id give u for the price of shipping if u chose to keep them and cut the bumpstops. they stops are from a 02 though not sure if they are the same stops.
  3. predavore
    Bump....
  4. predavore
    Bumps...
  5. burtonboy00
    burtonboy00 Well-Known Member
    I know it says for WRX only but do you think they would fit on the base Impreza wagon?
  6. predavore
    That I'm not sure about. If I'm not mistaken, I think most 2.5i people use the suspension (struts, sways and such) from the WRX and STi. I wonder if anyone else can pipe in about this???? Maybe start a thread about it?
  7. burtonboy00
    I'm hoping that they are interchangeable, as of now I have front and rear sway bars that were for a WRX, unless the dampers are completely different then they should fit. I just dont want a $120 mistake.
  8. predavore
    $300 2009 WRX struts should fix a $120 spring mistake. (maybe...??)
  9. burtonboy00
    MMM out of budget as of the moment
  10. predavore
    I'd look at 3gwrx.com and see. I'm on there now trying to find an answer.
  11. burtonboy00
    How much of the bump stops need to be cut?
  12. predavore
    Only about 1.5" or half. I find it to be a bit excessive. Considering these only drop the car another half inch lower than the STi pink springs I already have. I would only cut maybe an inch.
  13. MNGman
    MNGman Well-Known Member
    The springs will fit on a base model.
  14. burtonboy00
    Sweet, you have a PM
    Sent from my Droid using Tapatalk
  15. predavore
    I even have spring compressors if someone needs to borrow them. I might even be able to drink you're booze and supervise.
  16. predavore
    Sold!!!
  17. badbennyb
    Congrats! I'll close it up.
