gl turbo block...???...help...
Discussion in 'Modifications And Maintenance' started by wagonL, Apr 6, 2005.
  1. wagonL
    wagonL Well-Known Member
    well...i have a 93 ej18....and is it possible to put in a gl wagon turbo block on with my heads? or any dohc heads...??? or no this engine block wont fit...well...thanks for looking and helping..
    wagonL
  2. AWDimprezaL
    if the 1.8 is the same as your 1.8 then yes, but you'll have alot of compression, and wont be able to run alot of boost
  3. Dynapar
    correct me if i am wrong but isnt the GL block a EA, while the L block is an EJ. which means you will need a tranny converter plate.
  4. morganm
    morganm New Member
    Correct Dynapar; he'd need the adapter plate between the bellhousing halves.
    An EJ22 NA would give you more power than an EA82T and bolt upto your current tranny.
  5. Dynapar
    *feels powerful with profound subaru knowledge*:cool:
  6. LVT
    LVT Well-Known Member
    Don't do it.....
