New In Box Tactrix 2.0 with all 3 adapters - $150 Two EJ205 shortblocks, one was from a crashed car that cracked the oil filter mount on the case, the second was pulled due to rod knock. Should be able to put the good rotating assembly in the good case and have a cheap used shortblock, a good project for someone with free time - $120 for both I have a GC 5spd driveshaft and GD pedal set with clutch master/slave cylinders that I was going to use for a manual swap - $100 for all Two sets of valve lifters, 8 shimless (497,497,498,498,505,506,507,508) and 8 shim over bucket (244,248,248,250,251,251,255,258). $25/set (If there is some sort of community repository for these I'll donate them) Dayco 95254 Timing Belt, fits 94-97 1.8 and 2.2 - FREE Parts are in Roseville/Arden Hills Pictures to follow
Tactrix SOLD Everything else half off: 5-speed swap parts - $50 all 16 buckets - $25 Timing belt - still free
Would you sell me just the clutch master/slave setup? OEM? Mileage? Can I get the part numbers on it? I wanna see if it works on a 04sti setup. Thanks
