damn nobody has one here in this state and Napa only carrys acdelco spark plugs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Here's the part numbers in case you run into a knucklehead parts guy at the dealership. GM boost solenoid for Typhoon, GM Part # 1997152 Pigtails, GM Part # 12102747
Peter, as a dealership employee you should automatically get a discount, just call the local GM place and tell them who you work for. I can get them for about 17 bucks for the solenoid and 10 bucks for the pigtail.
buying the gm typhoon is a complete rip off it you get it from the dealership. go to rockauto like i said before
You don't necessarily need one ASAP. You can run those maps on the stock BCS until you get the GM one in -- you'll just run really low boost levels, that's all.
Looks like my memory isn't what it used to be...it'd be around 19.54 for the BCS and 20.66 for the pigtail. My bad.
lol, rockauto.com it is then. For some reason, I guess they use different part numbers: ACDELCO solenoid part # 214474 ACDELCO ABS modulator pigtale part # PT374
Its 'cause they use that pigtail for a bazillion different things and AC Delco has their own P/N system that's separate from GM's.
