Greddy Emange ultimate ??????
Discussion in 'Modifications And Maintenance' started by silverrs, Nov 21, 2006.
  1. silverrs
    silverrs Well-Known Member
    i have a greddy emanage ultimate, that i wanna wire up to my rs, and i also have a wire harness adapter, but it's wired up for a wrx, and i was wondering if anyone out there with a rs has the same management system as i do, i was told the wrx and rs harness only differ a little, but the guy i bought it from told me has no clue which wires to wire up or change around for an rs setup, i have my setup pretty much complete to run boost, and only thing left is the final tuning and dialing in on a dyno, i just wanted to save me a little $ and maybe wire up the emanage adapter myself, since i was told that it would only be a matter of switching a few wires around, then i could plug and play and have the shop concentrate on the tuning and dialing in~ unless i was told wrong and i would need major modification, either way i'm in a bind, so if anyone has any diagrams out there for a rs wire up w/ a greddy emanange ultimate adapter harness or any hepful information, i would really appriciate it.!. any info is greatly appriciated.!. thanks in advance.!.
  2. Colin
    Colin Well-Known Member
    It's called NASIOC. It's a website. It knows everything. <----none of this was supposed to be sarcastic.....just go there and search
    Edit: oh, and rs25.com is pretty useful too.
  3. AWDimprezaL
    You will need a wiring harness diagram, and ecu pinout
  4. Dynapar
    yes get a pinout for your ECU, then get one for the emange. start matching up wires. it isnt too hard to do so dont be imtimidated by lotsa of wires. i had to do this for my PP6.
    +1 for asking on RS25. bet a few of those guys have done it before.
