GrimmSpeed 160 Degree Thermostat - Product Release!
Discussion in 'Vendor Announcements/Sales/Discounts' started by GrimmSpeed, Jul 14, 2009.
  1. GrimmSpeed
    GrimmSpeed Vendor
    Link to Product: http://www.grimmspeed.com/catalog/product_info.php?cPath=91&products_id=162
    Price: 52.99
    First rule of thumb, excess heat kills engines and kills power. GrimmSpeed is on your side with our new 160 Degree Thermostat. Our thermostat will make an immediate and direct impact on your engine running temps. The 160 Degree T-Stat will bring your engine coolant temps down 20-30 Degrees.
    Many OEM style T-Stats can have a very negative effect on your vehicle, if they fail, they fail closed and your car will overheat. But not ours! If there is a failure with our T-Stat, it will fail in the OPEN position allowing coolant to flow and keep your engine temps under control.
    Given the fact most Subarus are turbo'd, this gives you even more of a reason to want to keep those coolant temps down. In turbo'd applications, the engine coolant must also cool the turbo and the engine oil. This places a greater strain on your oem thermostat...all the more reason to install the GrimmSpeed 160 Degree Thermostat!
    During testing, we have also found that our 160 Degree Thermostat keeps the engine coolant at a more stable temperature.
    Quick Facts:
    20-30 Degree cooler engine coolant temps
    Horsepower gains due to the ability to tune more agressively
    Less chance of the engine killing detonation
    Fails in an OPEN position compared to competitors products
  2. Bielke55
    Subaru Thermostats fail?
    OEM is rated at 172F
  3. AWDimprezaL
    You may set a check engine light for "coolant temp below threshold" Like my car did when I put in a napa 160 degree stat, it also got horse**** gas mileage. Maybe different on newer cars....
  4. putz
    putz Well-Known Member
    but the GS one fails..... Open. I think that is kinda cool. $53.00..... That ain't too bad, I'd hit that. ( I can haz a good guy discount please?)
  5. Bielke55
  6. Squiggly
    Squiggly Squiggly
    I had one fail closed on my RS 2 years after i got it. My car overheated and i had to replace the unit.
  7. Shibbs
    But the thing is - the cooling fans will still turn on at the factory temperatures, so this is really a moot point.
  8. AWDimprezaL
    Going down the road it will be a bit cooler. Idle it wont make that much of a difference though.
  9. putz
    so you cool water that is not moving through the block?
  10. wall of tvs
    As dumb as this sounds, you *may* need to get your car re-tuned if you install one of these.
    There is a correction table that applies a % to your ignition timing based on coolant temp. I do not recall off of the top of my head how much of a correction is applied and to what range.
  11. AWDimprezaL
    So 52 bucks for the stat and upwards of 100 for a tune? for 12 degrees difference?
  12. zyklon
    zyklon Well-Known Member
    This is on the 06. I'm not sure if Base Timing Alternate comes into play? If not, then there shouldn't be a change in timing between 140F and 194F.
  13. Bullwinkle
    Ok, thats enough guys. If you have constructive thoughts regarding this product, feel free to post them. Anyone else trolling or flaming will get points.
  14. shineynitelite
    there are lots of constructive posts in this thread..
  15. Bullwinkle
    Yes, there are now. Let's keep it that way.
  16. Iroc-Z
    Iroc-Z Well-Known Member
    You may not like the bad mouthing but the problem is this is a joke. And I am sorry if I don't want to see people suckered in because they don't know any better.
  17. GrimmSpeed
    GrimmSpeed Vendor
    lol, a cooler TSTAT is a joke?...what a very logical statement.
  18. shineynitelite
    so after reading the constructive posts, how do you justify your product being a logical upgrade?
    seriously, tell all the potential customers why they need your product.
  19. GrimmSpeed
    GrimmSpeed Vendor
    Did you not read the first post?
  20. shineynitelite
    did you not read the rest? please help us with the following topics in the products function ability. if you want to expand on the pricing feel free.
    - POOR GAS MILEAGE
    - CHECK ENGINE LIGHT
    - MAY (PROBABLY SHOULD) GET A TUNE
    thanks.
  21. Bullwinkle
    Ok, that's a little better. I'm not taking sides, but would appreciate a little more professionalism and grownup behavior around here.
  22. Aegis
    If you can do it without bad-mouthing or being cocky, then fine. Constructive criticism is what we're asking for here.
    And to be completely honest, your post had nothing to do with "helping out a user" or not "wanting to see people suckered in"
    It was banter, plain and simple.
    And another thing, us mods tell you guys this EVERY TIME Grimmspeed makes another product announcement. Just leave it be ffs.
  23. Shane86
    Shane86 Well-Known Member
  24. Bullwinkle
    I can, however, speak to this one. As per the compensation tables posted above, unless you're lowering the coolant temps below ~140 degrees (and on most other Subaru's, the compensations zero lower, at between 80 and 120), there is no need for a tune.
    The alternate compensation table is not relevant here as it represents the minimum timing that would be used as base ignition timing, if it exceeded the base timing plus all other compensations.
  25. Bielke55
    I wont post our Price. Ours doesnt have a fail safe mode... But when you have a failed thermostat thats wide open. Hows that any better for driving?
  26. shineynitelite
    thanks for the information, i stand partially corrected. i'l sit back and wait for the rest.
    keep it to PMs?
  27. h23
    h23 Member
    How about this.. If you don't like their product, don't buy it.
  28. Iroc-Z
    Most of the time it wont leave you stranded.
  29. Iroc-Z
    Just because you make an engine run cold does not make it better or create more power. Having to cold of stat can also cause overheating problems.
  30. Iroc-Z
    I get what your saying. I will file it under CS for later viewing.
  31. Wakaba
    Wakaba BANNED
    this IS MNSUBARU afterall, nothing less than grownup!
  32. readymix
    I have run a 160* t-stat for over 4 years now without any CELs or other issues. It is likely the same unit that is being sold here under a different branding.
    It did not require a retune, and ran just fine. The best feature of this thing is that it fails in the open position, meaning that in the unlikely event it DOES fail, you still get coolant flow.
  33. carl
    yea not sure what the big deal is, i ran a similar tstat back in my sr20det (prone to running somewhat hot)
  34. Nuke
    Alternate shouldn't kick in at all.
    When tuning Fuji's previous setup, he too, had a 160* thermostat, drilled, and nothing fishy ever happened. Car ran normal.
  35. ImportImage
    ImportImage Vendor
    tough crowd! best of luck justin, from previous sales im sure they will sell like crazy. maybe not as much as your magical ebc's have but they will sell. usually the northern guys like a little bit hotter thermostat, any plans on making any 170's?
  36. FuJi K
    No need for a tune. If I'm not mistaken this one should be the SAME as the Crucial Racing one. I didn't much like the fail safe thiny. Anytime it DOES overheat if you forgotten to plug in your fans, it'll lock the stat OPEN. Even when it cools down, it'll be LOCKED OPEN. When the stat is HOT, it is not likely it'll shut, it'll stay OPEN. SO when you have overheated your car, you need to drain your coolant or water with Water Wetter and UNLOCK the thermostat so it can close. If not you are likely to run COLD on cool nights because the stat is WIDE OPEN.
    I had no issues running this in the cooler months. I bent the locks apart to keep the stat from LOCKING OPEN. I didn't like that feature. If it overheats, you'll see the temps on your temp gauge. You're NOT gonna let the car run, are you??? lolz
  37. Iroc-Z
    Stock opens at about 172.
  38. Squiggly
    Squiggly Squiggly
    Yeah but the car actually runs around 190
  39. stoooo
    stoooo Well-Known Member
    When my water pump sprang a leak on the 2.5RS, I had it replaced at Bloomington Subaru Acura (not my 1st choice, but it was convenient as I drove past it on my way to and from work). The t-stat on the new pump assembly was faulty, and the car started to overheat about half way to Eden Prairie. To their credit, they replaced it with a fresh one the following day, but I wasn't real happy about having to run it at 236F along 494 (I had the laptop plugged in, so I knew exactly how hot it was getting).
    So, yes, OEM t-stats fail (even brand new ones), and when they fail closed, the car overheats. I'm not entirely sure of the benefit of running a t-stat that opens at a lower temp, but having been on the wrong end of a failed t-stat, failing open seems like a bloody good idea to me.
    Stuart.
  40. shineynitelite
    yeah and a 160 wont run at 160
  41. AWDimprezaL
    My stocker runs at 174 or so @ cruise (on an actual gauge). The same stat they use on all EJ motors.
  42. h23
    h23 Member
    I run a cooler tstat and I have no complaints. No CEL's, no problems. Let the man sell his product. If you don't want it, it's simple.. Don't buy it. There are wayyy more products out there that serve less of a product than this. Go bitch about the turbo whistler or the interfooler if you want to bitch about something that's useless.
  43. Roon
    Roon Well-Known Member
    Good luck Grimmspeed, looks like contrary to popular belief the product will help some folks out.
  44. ImportImage
    ImportImage Vendor
    if you've ever run a 160 up there in MN in the winter with an upgraded radiator. then you would know it takes a bit longer for the car to warm up.
    I've been selling thermostats for a long time. the northern folks like the 170's better sure it may only be a few degrees, but with the added failsafe especially when changing radiator/hoses it's the extra piece of mind customers may want. It may not be for you, but i assure you 160 and 170 degree thermostats do not sit on my shelves or collect dust :)
