GrimmSpeed 44mm EWG Up pipe - Product Release!
Discussion in 'Vendor Announcements/Sales/Discounts' started by Justin, Dec 10, 2008.
  1. Justin
    Justin Well-Known Member
    Yes, thats right..its here!! GrimmSpeed introduces the External Wastegate Up Pipe with 44mm V-Band flange.
    WHAT IS IT?
    An external wastegate allows the exhaust gases to be diverted prior to entering the turbo. Dumping the exhaust gas prior to the turbo helps with boost control, maintains boost longer in the rpm range, and extends the life of your turbo. Our pipe is fully built stainless steel EWG Up pipe and stainless steel dump tube for turbo Subarus. Monster thick SS flanges. New on our pipes for this product release...CNC cut flanges for closer tolerances! We have added a flex section which extends the life of the product and will lead to less exhaust leaks
    because the pipe can flex vs. warping the flanges in a non-flex setup(inturn creating leaks).
    Also new for this product release is the added support underneath the side-outlet. We haven't had issues in the past with cracking, but we just want to make sure it stays that way! Just another way we keep going above and beyond for you!
    WHY DO YOU NEED IT?
    Reason for switching to an EWG setup includes:
    :) Quicker turbo spool by allowing the exhaust gas to exit pre-turbo. There is alot of turbulence in the stock turbo at the internal wastegate so by moving the wastegate out of the turbo you get rid of this nasty turbulence thus improving the effiecency of the turbo as well.
    :) More efficient wastegate design that has a bigger diameter than stock allowing for the exhaust gas to be released quicker.
    :) Hold peak boost longer. This allows you to run a lower peak boost and increase HP at the same time.
    :) Much larger than the stock internal wastegate
    :) No more boost creep...EVER!
    GAINS?
    Users should expect gains in the 15-40hp range when tuned for the EWG setup.
    Another unique aspect of our package is that we include a bracket that holds your stock internal wastegate shut. This is great because you will no longer have to weld your turbo door shut which means you have no chance for leaks and you can revert back to stock anytime you want with no hassle.
    FITMENT
    02-08 WRX
    04-08 STi
    05-08 LGT
    05-08 FXT
    93-01 Turbo Subarus
    PACKAGE CONTENTS
    44mm V-Band EWG Up Pipe
    Dump Tube
    Area1320 Bracket to hold stock wastegate closed(no more welding!)
    5 Studs for Up Pipe
    LINK TO PRODUCT
    http://www.grimmspeed.com/catalog/product_info.php?cPath=22&products_id=147
    PRICE
    329.99
    We offer ceramic thermal coating for both pipes(up pipe and dump tube) for 29.99.
    Justin
    www.grimmspeed.com
    AIM: GrimmSpd
    612.481.5731
  2. subynate
    subynate Well-Known Member
    thats puurdy
  3. carl
    looks awesome justin!!
  4. Soupboy
    Soupboy Well-Known Member
    Wow, another winner! Is there a shop vehicle we can listen to it installed on?
  5. ZoisSTI
    ZoisSTI Member
    Mmm sick.
  6. predavore
    predavore Well-Known Member
    That picture would be a great spot to advertise the internal WG locker.
  7. putz
    putz Well-Known Member
    Justin, I may have to call you for this one!!!
    I will just have to rob wee lil Winry's college fund...
    Maybe not.
    Looks awesome though!
  8. Justin
    thanks guys! we've been working on this one for a long time now and it turned out just like we wanted!
    well it was, now its off and the 38mm is back on the car. however, the car is completely gutted so it doesnt sound like your normal full interior sound.
    :emo: i know...we were out of stock of the td04 ones. maybe i can try to chop one in or something lol.
    sounds good..give us a ring! isnt that what you have student loans for, car parts and beer? :)
    Justin
  9. idget
    Looks good!
    What's the internal diameter of the uppipe? Also, available in 3-bolt flange?
  10. Justin
    i dont have the exact info on me right now(at home) but it is about 1.92" on the inlet size and it funnels down to 1.71 or so on the outlet side. we found this to be the optimal ID size because it is the biggest you can go on the inlet side without having the gasket be in the flow path, and the outlet is a good matchup to most common turbo inlets.
    no 3-bolt available now but it is definitely in the plans for the future.
  11. Zombie
    Zombie Well-Known Member
    Looking great! Do you have a block off plate and V-band clamp available separately?
  12. GrimmSpeed
    GrimmSpeed Vendor
    Not at the moment but it is something we will be working on in the near future.
    Mike
  13. Michael48
    Michael48 Member
    So is this a good setup for a stock wrx? what other hardwared is recomended? I like the cobb system and sound, I have a VF39 and STI top mount intercooler I'm waiting to install until I find the right exhasut to finish it.
  14. Shibbs
    Oh man, I can't do the "I'll wait until I can finish it" route. If I get a part that CAN go on by itself, ITS ON. hahah
    This is definitely a nice looking piece tho. For sure.
  15. carl
    saw them in person today - they really are outstanding! I'd have 5 of them on my car right now if it wasn't slated for n/a
  16. Nuke
    You'd just switch out your uppipe with this one, add the wastegate and the dump tube, and find a way to close your internal wastegate (Grimmspeed sells the bracket). Tune, done.
  17. GrimmSpeed
    GrimmSpeed Vendor
