Anyone have a grimmspeed gasket and adapter for 2015 + sti stock down pipe to the invidia exhaust that I can buy?
Are you sure you will need an adapter? I believe you will only need the adapter if you are running the aftermarket downpipe to the stock cat back. If the pipe sizes (likely 3-inch for both) match. You should be fine.
