GrimmSpeed Downpipe Arrives!
Discussion in 'Vendor Announcements/Sales/Discounts' started by Justin, Dec 6, 2008.
  1. Justin
    Justin Well-Known Member
    St. Paul, MN
    GrimmSpeed introduces the Catless Downpipe for Subarus. GrimmSpeed’s Catless Bellmouth Downpipe is one of the first modifications that should be done on your car!
    The OEM downpipe contains two very restrictive catalytic converters, killing the power potential of your car. Our downpipe is a full 3” CNC mandrel bent design with a wax-casted bellmouth. Using a unique wax-casting design for our bellmouth, it has allowed us to create a very smooth bellmouth that allows for optimal flow. The outlet of the downpipe has a standard 3” 2-Bolt flange that will mate up with most aftermarket cat-backs on the market. In typical GrimmSpeed fashion, all pieces of the downpipe are made from 304 stainless steel; flex, bellmouth, piping, even the flanges! Stainless steel flanges are very rare, most competitors try to save money by going with a polished mild-steel flange, not us!
    By using a downpipe that is catless, it allows you to fully maximize your exhaust flow which will increase the ability of your car to produce huge horsepower and torque gains. Turbo power, response, and efficiency is greatly improved. Once you have added our downpipe to your vehicle, you must be retuned.
    Every downpipe has a second o2 Bung with cap for those who wish to monitor o2 levls. The secondary o2 Bung is located in the bellmouth for ease of installation. Having a secondary o2 Bung saves you time and money because you will not have to pay a shop to install one for you.
    If that wasn’t enough reason to go with the GrimmSpeed Downpipe, we have went one step further and added a flex-joint in the downpipe. Why do you need a flex section in the downpipe you ask? Adding a flex joint has two main functions; allows the pipe to expand/contract during heat cycling with out cracking welds and it makes installation much easier. All aftermarket cat-backs are a bit different in their fitment, the flex joint allows you to mate our downpipe to almost any aftermarket cat-back with complete ease.
    Replacing your factory catalytic converter sometimes causes a ‘cat converter efficiency’ check engine light. You can either use tuning to delete this CEL or you can use a mechanical fix.
    All GrimmSpeed exhaust products are intended for off-road use only.
    PACKAGE CONTENTS
    GrimmSpeed Catless Downpipe
    GrimmSpeed Turbo>DP Gasket
    GrimmSpeed DP>Catback Gasket
    Bolts and Nuts
    PRICE
    369.99
    http://www.grimmspeed.com/catalog/product_info.php?cPath=22&products_id=146
    Justin
  2. mnstilynwrx
    mnstilynwrx Well-Known Member
    Minneapolis, MN
    Very nice! well done I think you will get a lot of business out of that. keep the parts coming.
  3. hella_sti
    hella_sti Well-Known Member
    looks alot like the cobb unit, is this like the cross pipe and made overseas or is it fabed and welded in MN?
  4. predavore
    predavore Well-Known Member
    Southern 'Burbs
    Very Nice! Have you thought about an EWG recirc version?
  5. Justin
    St. Paul, MN
    thanks!
    definitely not the same as the cobb unit. companies suppliers are their biggest secrets now arent they? did you purchase one of our crosspipes?
    actually yes i have. definitely may be an option in the future.
  6. curly2k3
    Silent Hill, Jackass
    looks like a nice piece
  7. Justin
    St. Paul, MN
    thanks! i've been working on it the last 4 months. the final version was about the 5th rendition lol
  8. Soupboy
    Soupboy Well-Known Member
    St. Louis Park, MN
    Very nice looking part Justin.
  9. blackozone
    Dirrty Souf
    The bellmouth looks like cast iron, what material is that made out of?
  10. Justin
    St. Paul, MN
    cast stainless :yumyum:
  11. predavore
    Southern 'Burbs
    No divorced version?
  12. wall of tvs
    dream ftw
    That 2nd bung is going to be worthless for egts since the established temp guidelines that everyone uses are all measured at the head.
    You'd be better off marketing it as a secondary bung that can be used for TEMPORARY wbo2 usage during tuning sessions. Have you thought about either moving the secondary bung or adding a 3rd bung down to a location for permanant mount wideband sensors?
  13. Paul Revere
    In the land of ice and snow.
    Tom said it best, I had the same question.
  14. wall of tvs
    dream ftw
    Just tryin' to help out a friend. :)
  15. Justin
    St. Paul, MN
    where does it say EGT? its is a secondary o2 sensor meant for a wideband o2 sensor.
  16. AWDimprezaL
    Monticello.
    it looks really good, And i'm being dead serious, If I wasnt done modding turbo subarus and i needed a DP...This one would definatly be on my list, congrats justin.
  17. Se7enrex
    Se7enrex Well-Known Member
    All over Slingin' Parts for the Hungry
    Awesome, its finally out!! GrimmSpeed has been working so hard on producing the perfect downpipe!!! And 1st hand experience says that they are made with the highest quality materials every time. You guys should have seen the testing we did to make sure its pefect!! Wish I had my STI still, I'd buy this baby in a heart beat!
  18. wall of tvs
    dream ftw
    Nice ninja edit.... ;)
  19. Paul Revere
    Yeah I see what he did there. ;)
  20. Justin
    St. Paul, MN
    :laugh:
    thats what i get for creating a product description at 1am. however i did ninja edit before tom posted about it.
  21. wall of tvs
    dream ftw
    Grimmspeed shareholder's meeting @ 3:15am, lolzzzz! :p
    Nice downpipe, btw. Are you going to offer these in a coated version as well?
  22. Paul Revere
    Yes it's a nice piece, and that would be a killer option.
  23. Justin
    St. Paul, MN
    absolutely. we havent figured out an exact price yet(probably around 100) which is why it isnt on the website yet.
  24. Bullwinkle
    Saint Paul
    Yeah, if you're redesigning again, this is what I would suggest. Something 12-24" back from the bellmouth.
  25. Impreziv
    Impreziv Well-Known Member
    Hopkins
    And the bellmouth is not cast utilizing the standard sand casting methods, its cast using another quite smoother substrate for the molds!!
  26. Impreziv
    Hopkins
    Oh and on another note, I don't beleive this was mentioned before but for all you JDM guys out there, I mean with Non-USDM swaps. The stock narrow band o2 sensor is located just in-back of the turbo and you can simply move the bolt to the lower hole and use your stock o2 sensor in the upper hole. Thats what I have done and it works great, has for the last couple years just fine.
  27. Shibbs
    What kind of joint is under the flex section? Slip-fits I'm hoping for this price...
  28. Dream
    south
    Look's like a nice piece!
  29. Treylizardo
    Treylizardo Active Member
    St. Paul
    Do you have any plans to release one with a cat in the future?
  30. predavore
    Southern 'Burbs
    I'm sure there are plenty of aftermarket cats out there already. That's one spendy part and the cost fluctuates so much. I wouldn't put one on if I were making them. Use a test pipe and tune for it.
  31. idget
    falcon heights
    This looks like a 1-piece downpipe. An aftermarket cat would have to be welded into this downpipe or the midpipe (if it'll even fit). Where does a "test-pipe" come into play? This downpipe already eliminates both post-turbo cats.
    Considering Grimmspeed's market spans well beyond MN, a catted version would be a marketable option.
    Anyway, nice looking piece. Is this the only wrx/sti downpipe with a flex joint on the market?
  32. Nuke
    Saint Paul
    I was questioning that also. I have not seen any others (yet?).
    A catted one would be great
  33. webcrawlr
    webcrawlr Well-Known Member
    minneapolis
    Turbulence? You see plenty of them on mid pipes much further "down the line" from the turbo.
    +1 on a cat.
  34. Justin
    St. Paul, MN
    yeah a cat will come at somepoint...we've had alot of questions about it on all the forums.
  35. WRXEcho
    WRXEcho Well-Known Member
    New Hope - MN Bugeye Mafia #666
    I believe UR (Ultimate-Racing) makes one with a flex joint... At least I thought I read that somewhere.
  36. Mortasaurus
    Mortasaurus Well-Known Member
    Bloomington, MN
    Isn't UR for Unorthodox Racing? That is what is written on my Unorthodox Racing pulleys and the included stickers.
  37. idget
    falcon heights
    I think most people mean Ultimate-racing when they say "UR." They fabricate a number of parts including rotated turbo kits compared to Unorthodox who mainly do pulley's an oil caps and such.
  38. Mortasaurus
    Bloomington, MN
    Well I stand corrected.
