1. GrimmSpeed Master Cylinder Brace ( fits 93-07 Impreza, 97-08 Forester, 90-99 Legacy) This is brand new and comes with everything. They sell for $99, I'll take $75 SOLD 2. Autometer gauges brand new in box with wiring harness kit Sport Comp 3327 Oil Pressure Gauge (sells for $59.90) Sport Comp 3391 Volt Meter (sells for $39.90) Sport Comp 3337 Water Temp (sells for $45.90) $60 for all 3 gauges and the wiring.
I'd like to add that I also have a set of brand new Whiteline rear subframe bolts. "The Whiteline 02-07 WRX & 04-07 STI rear subframe lock bolts will remove the slop from the rear end. The WRX and STI have a rear subframe that is held to the car using soft OE bushings that allow movement. This excessive movement reduces the effectiveness of sway bars, lateral links, and control arms. This inexpensive kit from Whiteline threads bolts into holes that already exist from the factory. The bolts install simply with hand tools and will stiffen up the rear end of your 02-07 WRX or 04-07 STI." SOLD
The master cylinder brace is sold but the bolts and gauges are still for sale. I will take a best offer for both.
