GrimmSpeed Project Impreza L/WRX Dynos
Discussion in 'Modifications And Maintenance' started by GrimmSpeed, Feb 3, 2008.
  1. GrimmSpeed
    GrimmSpeed Vendor
    We're going to use this thread to post our dynos for our current project car. I also want to use this thread to show you the gains you should obtain with GrimmSpeed parts on a setup like this(wrx 2.0 engine).
    The car is a 96 Impreza L with an 05 2.0 WRX swap. I put the engine/exhaust/intake together completely stock just so i could get the car running and work out any bugs before i start mod'ing the engine, etc.
    Build thread can be found here:
    http://www.mnsubaru.com/forums/showthread.php?t=14941
    We are using Data Log Lab(www.dataloglab.com) for all of our plots. We are using SAE correction so that way we can really get apples to apples numbers when we are taking pulls on different days. We are using this software solely for showing comparisons of before and after affects of mods/tuning.
    Tuning wise we are using enginuity/ecuflash(www.enginuity.org). The enginuity site has been down for awhile but i spoke with owner of enginuity and he stated that it should be back up soon.
    Well i just got done with a tune on the completely stock setup....
    STOCK: 168HP/174TQ
    STG1(no mods, just tune): 184HP/191TQ
    So we are looking at gains of 16HP and 17TQ...not to shabby for some mild tuning. Boost peaks at 16.5psi and tapers to 12psi at redline. Of course i'm completely running out of injector around 5500rpm so i need to get some new injectors in there quickly.
    I know it would be better to put it on the dyno after every mod so we can see afr's but we simply dont have the funds to be dyno'ing the car every few days. The newer road dyno'ing software is pretty accurate these days so i'm not to worried.
    Justin
    www.grimmspeed.com
  2. Ronnie@RSmotors
    The base seems kinda low. Have you got other numbers from other stock cars using the same software?
    Gains are impresive thou.
  3. curly2k3
    not bad, car is pretty sweet, cant wait to see it developed more
  4. GrimmSpeed
    GrimmSpeed Vendor
    base numbers are about spot on with the average dyno. remember, this is a 2.0 wrx not the 2.5.
  5. SubeN'Siren
    SubeN'Siren Well-Known Member
    "stock" meaning you are using all stock (3 cats) exhaust and intake piping, and the injectors that are maxing, are they stock WRX items as well?
  6. Shibbs
    What dyno, if I completely missed it?
  7. curly2k3
    "We are using Data Log Lab(www.dataloglab.com) for all of our plots. We are using SAE correction so that way we can really get apples to apples numbers when we are taking pulls on different days. We are using this software solely for showing comparisons of before and after affects of mods/tuning."
    you did miss it
  8. Justin
    Justin Well-Known Member
    correct...stock as stock can get. yes the injectors are 05 wrx injectors. max'ing out starts at about 5300rpms.
  9. curly2k3
    interesting...why are the injectors maxing out on such a stock system? i guess i feel like i am missing something here
  10. SubeN'Siren
    I thought I heard you could max the injectors on the stock turbo, but at stage 1?
  11. Justin
    the injectors are to small from the factory...when you start tuning that makes it even worse. idcs at 5300 are between 102-108%. right now we are just having to taper boost off alot. trying to find some deatschwerks injectors asap.
  12. Justin
    Code:
    [FONT=Arial]4744[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]11.5[/FONT] [FONT=Arial]95.13[/FONT]
    [FONT=Arial]4928[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]12.5[/FONT] [FONT=Arial]97.76[/FONT]
    [FONT=Arial]5074[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]13[/FONT]  [FONT=Arial]97.43[/FONT]
    [FONT=Arial]5119[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]14[/FONT]  [FONT=Arial]99.38[/FONT]
    [FONT=Arial]5330[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]14[/FONT]  [FONT=Arial]102.34[/FONT]
    [FONT=Arial]5423[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]15[/FONT]  [FONT=Arial]102.96[/FONT]
    [FONT=Arial]5547[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]15.5[/FONT] [FONT=Arial]102.96[/FONT]
    [FONT=Arial]5708[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]15.5[/FONT] [FONT=Arial]105.93[/FONT]
    [FONT=Arial]5854[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]16[/FONT]  [FONT=Arial]106.16[/FONT]
    [FONT=Arial]5912[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]16[/FONT]  [FONT=Arial]107.09[/FONT]
    [FONT=Arial]6019[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]16.5[/FONT] [FONT=Arial]106.58[/FONT]
    [FONT=Arial]6144[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]17.5[/FONT] [FONT=Arial]108.61[/FONT]
    [FONT=Arial]6286[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]21[/FONT]  [FONT=Arial]108.63[/FONT]
    [FONT=Arial]6350[/FONT] [FONT=Arial]16[/FONT] [FONT=Arial]21[/FONT]  [FONT=Arial]108.38[/FONT]
    first column rpm, last column idc
    freakin a it wont copy over right..sorry
  13. curly2k3
    wow, over 100% duty cycle? i thought the injectors were better than that.
  14. Justin
    i checked the non-tuned stock log i took and i was at 88% idc's at that point already.
  15. SubeN'Siren
    "winter" gas, or non-ox?
  16. curly2k3
    really, wow... thats almost disappointing from Subaru in itself. I thought you could do a full stage 2 flash with the stock injectors tho...what are the injector sizes, IDCs, and pulses like on other years besides 05?
  17. Justin
    cant remember what i put in...either bp or holiday 91/92
  18. piddster
    I just really want to see a before/after plot of a pnp coated e-mani with your nice crossover and a fairly aggressive setup. It may already exist, and if so, point me in that direction.
    Deatschwerks does some good work. I've been running their SR20 650's for over a year without problems. I just wish I would have got the 8**cc set to begin with. I suggest you do the same.
  19. Nuke
    OMG, Holiday gas FTL!!!
  20. curly2k3
    this, i know my car runs like complete crap on any holiday gas at all... i had been told in the past that they use that soy based crap and add a few different things to their gas, neither of which i really have any intent on burning in my car.
  21. Justin
    yeah i want the 850's too but they are freaking $499. 750s are 399 so i might go with those, however if i'm going ewg i need all the injector i can get to keep that boost up so i might just have to flip for the 850s
  22. Grayguy
    Grayguy Well-Known Member
    So basically, this is a stock WRX with the GrimmSpeed Piping on it, and retuned?
    oh, and 810cc Deatschwerks FTMFW! pretty sure I wont need to be upgrading them.
  23. Nuke
    Get some 1000cc Injectors, Go E85!
    and treat your car with some BP/Shell gas
    No Holiday please, SA also
  24. curly2k3
    i am with Nuke, Shell/BP..no SA/Holiday...
    however, i am still not sold at all on E85, the TQ is nice, but not a fan
  25. piddster
    Damn, they must have raised their prices. Even still, it will save you money in the long run by getting the largerest injectors possible. Learn from my mistakes.
  26. Justin
    its bone stock right now...no grimmspeed products on it yet
    ok ok..i'll stick to bp/shell
    my plan right now is to build a td04 instaboost monster... e85, ewg, and pnp madness.
  27. piddster
    If you want an instaboost monster, get a disco potato.
  28. SubeN'Siren
    What gear is this pull in? Or would it not make much difference in injector duty?
  29. Justin
    3rd gear...i would do 4th but i dont feel like going to jail
  30. piddster
    hmm, sounds like you need a V1...
  31. SubeN'Siren
    :cool:Word
    I like to keep my driver's license too;)
  32. Grayguy
    oo, interesting. SO I assume your going to put all your grimmspeeds stuff on it, and re-dyno it after that? I would be very interested it that, since i basically have a stock WRX with .2 more liters.
  33. piddster
    Your heads do flow better, but yeah, close enough.
  34. Justin
    exactly. you will be able see every step of the way. pictures of the installs and what not will be in the main build thread and the power results will be here.
    i'm just happy this guy is finally running. :)
    turboback is going on asap(not grimmspeed stuff as we dont make a turboback) so we'll do some tuning for that and i'll put up the dynos for that as well.
  35. Ej22TIM
    Ej22TIM Well-Known Member
    this is pretty sweet, its amazing you did that much work and kept it bone stock. props on the build, shes come a long way!
    now lets see what some ported everything does!!!!
  36. Justin
    thanks! yeah its pretty funny, the only thing on the entire car that is stock is the engine and exhaust lol.
  37. Ej22TIM
    thats the best thing if you have a dyno avail, let me know what the pnp turbo does! ah who am I kidding im buying that regaurdless......
    got any engine pics?
  38. SubeN'Siren
    "td04 instaboost monster... e85, ewg, and pnp madness."
    Pretty much my end goal as well, though I won't be switching to e-85 until there is a station within 10 miles of me that sells it.
    I'll be watching this thread!
  39. Justin
    many pics here.. http://www.mnsubaru.com/forums/showthread.php?t=14941
    its a good goal for sure. my goal on my old wrx was going for the td04 high hp record but that fell short when she blew up.
  40. Grayguy
    I am looking forward to this info. I don't think I'm going to have the money for the Turbo/tranny setup I really want for quite some time, so I want as much outta my TD04 as possible. The only turbo car i've driven is a bone stock WRX, and that was a blast, so I can't wait to see what I can get outta mine!
  41. bikerwriter
    bikerwriter Well-Known Member
    You can go to Stage II but your tune won't be very aggressive. The old fuel system is still the limiting factor. You run out of IDC long before anything else...
  42. wall of tvs
    Go look at my dyno plots if you think e85 sucks. :biggrin:
  43. Vorgto
    Vorgto BANNED
    i don't think he was saying it sucked.. just that he isn't a fan of it. we all know e85 can make some great power!
  44. Dynapar
    cool cool! I have been looking forward to this thread. These datalog software seems to be pretty accurate for a baseline. I am impressed.
  45. curly2k3
    yeah i never said it sucked, i personally dont care for it at all is all
