Dont feel like spending $500 for a new set up butterfly-less tgvs or $600 for a JDM Intake Manifold? For less than 1/2 the price you can get the same exact benefits from our TGV Deletes. In this process we take a stock TGV and completely gut it, which includes taking out the metal plate, butterflies, and bar. These will allow for maximum flow through the TGV. Minimize the engine's heat from entering the TGV's with our ceramic coating. It is very important that heat stays out of the TGV's because this is the last transfer before the intake air enters the engine. Cooler intake air equals more hp. Customers have seen gains of 15+ whp/wtq. We've also seen third party flowbench tests showing an increase from 330 cfm to 480 cfm! As far as where the gains occur in the power band, your entire power band is going to see an improvement with our TGV Deletes. On a typical STG 2 setup you are going to realize an increase of 5-10tq/5-8hp in the low end, 10-15tq/8-12hp in the mid range, and 5-10tq/5-8hp at the high end. As you can see in the dyno graph, max gains are going to occur in the mid range. These will also give you a quicker turbo spool up. If those gains weren't good enough for you, wait till you add a bigger turbo...the bigger the turbo you put on the bigger the gains are going to be from getting the GrimmSpeed TGV Delete. Yummy! Thermal Coating!! Intake Manfiold Side Head Side Dyno Graph This dyno graph was provided to us by one of our customers. Top Side by Side Pricing TGV Delete Service WRX & STi $179.99 Ceramic Thermal Coating $24.99 100% Refundable Core Fee $100 Click below for WRX TGV Delete http://www.grimmspeed.com/catalog/product_info.php?cPath=24&products_id=35 Click below for STi TGV Delete http://www.grimmspeed.com/catalog/product_info.php?cPath=24&products_id=44 Any questions please contact us via email, phone, or AIM! Josh www.grimmspeed.com [email protected] AIM: GrimmSpd phone:612-481-5731
